What's the purpose of C1 and C2 in this circuit?
devop
Full Member level 1
1,Are C1 and C2 are only used for start up ?Do they have any other usage?
2,Is C1 larger or smaller than C2? why?
3,how can I calculate C1 and C2
the usage of C here?
what's the function of this circuit?
Re: the usage of C here?
Is this a current source ?
If so , maybe C1 and C2 is used for decreasing the effect of noise on
power and ground lines .
I have modifyed the picture:)
to get a non vdd related voltage ref
it should be a current source generation circuit, C1,C2 are decouple capacitors for noise elimination.
This is a constant gm current source.Caps are not used for start up here.C1 is a decoupling cap,but C2 will make the psrr much more worse for the noise in the power line will be shorted to the gate of nmos at the high frequency.
What does the circuit do??
You could think about frequency stabilization. (Besides the usual uses)
It is used for the noise suppression.....
regards,
$ujith
This is the Vdd independent biasing circuit. It should have a different startup circuit. The only reason I can think of to have those caps is for noise suppression as this circuit will be used for DC biasing.
capacitor used for filtering the noise,
C2 make the PSRR+ worse;C2 also filter the noise
how can I balance it?
another question, how can I calculate it?
if connect C2 to the gnd,is there any difference?
If C2 connect to gnd ,I thik it will work too.
some text says that this structure can also provide a PTAT current,can anyone explain?
thanks
why it can't work as a startup circuit?when power on,C2 makes the gate of the NMOS to VDD,start up the circuit ?
