Looking for synthesizable VHDL /Verilog code for a simple adpll
janarthanan
Newbie level 6
i need vhdl/verilog code for adpll. Adpll may have any architecture,
kindly help me
thanks in advance
adpll code
Hi
I have one PDF on adpll. It is easy to impliment from this.
Thanks
adpll vhdl
kindly help me
thanks in advance
this is the code u can use
DPLL -- MOORE MACHINE
// Title : DPLL
// File Name : dpll.v
// Project : USB 1.1
// Description : Behavioral
// Date By version Change description
//"Output of dpll" -- clk_rcv
//"Clock" -- DPLL clock
//"rcv" -- Input to nrzi decoder
module dpll(clk_rcv,rcv,clk_high,rst);
output clk_rcv; // Clock output of DPLL
input rcv,clk_high,rst; // rcv -- Input to DPLL
// clk_high -- 48MHz clock
reg a,b,clk_rcv;
parameter [3:0]sc = 4'b1100;
parameter [3:0]sd = 4'b1101;
parameter [3:0]s5 = 4'b0101;
parameter [3:0]s7 = 4'b0111;
parameter [3:0]s6 = 4'b0110;
parameter [3:0]s4 = 4'b0100;
parameter [3:0]s1 = 4'b0001;
parameter [3:0]s3 = 4'b0011;
parameter [3:0]s2 = 4'b0010;
parameter [3:0]s0 = 4'b0000;
parameter [3:0]sb = 4'b1011;
parameter [3:0]sf = 4'b1111;
reg [3:0] state;
reg [1:0]t;
always
begin
@ (posedge clk_high);
a= rcv;
end
always
begin
@ (negedge clk_high);
b=rcv;
end
always @ (posedge clk_high)
begin
if(rst)
state=sc;
else
begin
case (state)
sc:begin
if (b)
state=sc;
else
state=sd;
end
sd:begin
if(b)
state=s5;
else
state=sd;
end
s5: state=s7;
s7:begin
if(a)
state=s6;
else
state=sb;
end
s6:begin
if(b)
state=s4;
else
state=s1;
end
s4:begin
if(b)
state=s5;
else
state=s1;
end
s1: state=s3;
s3:begin
if(a)
state=sf;
else
state=s2;
end
s2:begin
if(b)
state=s5;
else
state=s0;
end
s0:begin
if(b)
state=s5;
else
state=s1;
end
sb: state=s2;
sf: state=s6;
default: state=sc;
endcase
end
end
always @ (state or a or b)
begin
t={a,b};
case (state)
sc:begin
casex(t)
2'bx1:clk_rcv=1'b0;
default:clk_rcv=1'b0;
endcase
end
sd:begin
casex(t)
2'bx1:clk_rcv=1'b0;
endcase
end
s5:clk_rcv=1'b0;
s7:begin
casex(t)
2'b1x:clk_rcv=1'b1;
default:clk_rcv=1'b1;
endcase
end
s4:begin
casex(t)
2'bx1:clk_rcv=1'b0;
endcase
end
s1:clk_rcv=1'b1;
s3:begin
casex(t)
2'b0x:clk_rcv=1'b1;
endcase
end
s2:begin
casex(t)
2'bx0:clk_rcv=1'b0;
endcase
end
s0:begin
casex(t)
2'bx0:clk_rcv=1'b0;
endcase
end
sb:clk_rcv=1'b1;
sf:clk_rcv=1'b1;
endcase
end
endmodule
i have one pdf on adpll
I want to use the adpll code for different frequecies from 2Mhz to 500Mhz does the above code suports.
adpll verilog code
For what purpose you use the ADPLL?
adpll vhdl code
I want use adpll for CDR and clock recovery from gapped clocks, in which the input comes with any frequency. I want to just load a control code based on input frequency.
adpll clocked by output clock
I dont download
