Problem with omitting nodes in a subcircuit herder using OrCAD PSpice
peleus
Newbie level 2
In pspice language syntax it is allowed to omit nodes in a subcircuit header according to the PSpice Reference.pdf. However, the simulator turns out an error that there is no subcircuit name during an X call. From my point of view the latter means that the simulator looks for at least one node and then for a subcircuit name. I have a serious interest on usage of such a subcircuit without any node.
Ex:
.subckt xx
v1 1 0 0V
r1 1 0 1k
.ends
x1 xx
Instantiating x1 causes an error but it should run. Is there any patch?
Re: OrCAD PSpice bug?
Pspice requires a node number in order do instance a component, you cannot
insert a component without these informations.
.subckt a b xx
v1 a b 0V
r1 a b 1k
.ends
and if you want to use several subcircuits in parallel
x1 1 0 xx
X2 1 0 xx
X2 1 0 xx
or in series
X1 1 2 xx
X2 2 3 xx
X3 3 0 xx
It's not true what you have typed concerning number of nodes. The following is an extract from the PSpice Reference Guide.
[node]*
An optional list of nodes (pins). This is optional because it is possible to
specify a subcircuit that has no interface nodes.
Similarly, if you take a look at X command, you'll see that the number of nodes is optional including zero.
Thanx for your effort Jonatan.
