Question in Verilog-A
shaikhsarfraz
Full Member level 5
I am using cross function in Verilog A.
The syntax is like
@cross(expr,dir)
Dir checks whether there is any zero crossing in the positive direction or negative direction.
Now if I want to set the threshold for this crossing something else(not 0)
then what is the syntax for that.
thanks
sarfraz
U can specify the threshold arguement just before the direction argument.
For example if u need to set a threshold limit of +2.5 then the syntax looks as follows
@(cross(V(clk)-2.5, +1)
Check out verilog lrm for any syntactical issues
Ok that was a good logaical method to get the threshold.
