How to define array variable in flash memory of MSP430F427 TI microcontroller?
london
Member level 4
How to define array variable in flash memory of MSP430F427 TI micro controller. I am using Code Composer Essential C compiler. The main command use for that is #pragma DATA_SECTION()
Re: Pls Help me!!
Hi
You can't define array of variable in flash memory - unless you wish to use the flash memeory to emulate EEPROM.
Ti has application note on how to use the flash memory as an EEPROM
See ti site and search MSP430 application note
All the best
Bobi
