How to detect High-Z state in VHDL
addn
Member level 1
hi
like some ICS,can be set 3 kind of working mode by 1 input pin
ex: input pin='HI' ->mode1
input pin='LO' ->mode2
input pin='High-Z' ->mode3
thank you
High impedance state is recognized by its logical strength
check this out
there no way high Z in VHDL for syntizable model
hello,
Iouri is right u cannot synthesize high impedance. I was telling u at coding view.
Thanks
Viswanadh
Hi friends,
The high Z is added in IEEE.std_logic_1164
Do check these links.
h**p://www.vhdl-online.de/tutorial/englisch/t_71.htm#pgfId-1017643
www.cs.du.edu/~cag/courses/ENGR/ence3830/VHDL/Lectures/VHDL.PPT
FYI, the slide is shown below...
Defined in IEEE package called STD_LOGIC_1164 (“standard logic”)
Contains 9-valued STD_LOGIC type for simulation and synthesis
‘U’= uninitialized
‘X’= forcing unknown state
‘0’= forcing 0 level (logic zero)
‘1’= forcing 1 level (logic one)
‘Z’= high impedance
‘W’= weak state, level unknown
‘L’= weak 0
‘H’= weak 1
‘-’= don’t care
STD_LOGIC initializes to unknown
hi friends
thank for your reply
1. In VHDL level for simulation, You can write VHDL for compare input as 'Z'.
2. Hi-Z is not mean for synthesis. 'Z' is for assign to bidirectional pin.
3. For hardware FPGA is not design to sense Hi-Z state. So you cannot implement to FPGA.
