Orcad error: Cannot load a metric netlist on top of an english board or template.
mr_byte31
Full Member level 5
after i have made my schematic design and created my netlist
and went to layout and make new pcb this error apears
AutoECO Report
FILE-A: C:\ORCAD\ORCAD_10.0\TOOLS\LAYOUT\DATA\1BET_ANY.TCH
FILE-B: C:\PSD_DATA\AVR\NETLIST\SH.MNL
If "*EOF*" immediately follows, no changes were made
Please convert.
*EOF*
Unable to complete ECO due to errors
1 error found
and the second one is
AutoECO Error Report
Please convert.
1 error found
can any body help
orcad+error
"Cannot load a metric netlist on top of an english board or template. "
convert board unit
inch---->mm
orcad load errors
i used mm not inch
but if the schematic is opened during making the board
can it make the problem?
Added after 1 hours 55 minutes:
i have changed from mm to inch and it worked
but what about if i want it mm?
Sorry guys.. I know this thread is almost 87 months old.. :roll:
But I do not want to create a new thread for asking a silly question.. and the question is:
Where can I change the board units to inches or mm??
I have created a sample file in Capture and trying to open it through Layout. I am getting this error;
"Cannot load a metric netlist on top of an english board or template."
Is this option of converting board units present in Layout or Capture?
And in which Menu item is this present..
Sorry again.. :)
ranjith_asp
Hi Ranjith,
Board units can be changed in layout.
SETUP-DESIGN PARAMETERS-DESIGN-USER UNITS. In this you can change your board units.
SHABU.
