sanders
Member level 3
hi,all.i have to set a model that lossy material is illuminated by plane wave in hfss9.2, but i have some questions here:
1 can hfss9.2 solve this problem?if no ,which software can be used?
2 if yes ,then how to set the incident plane wave( ultrawide band) in hfss?
3 "lossy " means what ? use "loss tangent" to represent or some other thing? i want the material has similar loss as earth, then how to make it?
4 can i inspect the distribution of e field in and around the loss material after simulation using hfss, that is because i want to compare reflect wave and travel wave with incident wave according to mag and phase.
5 any valuable model and info will be appretiated! sandersxiao@163.com
