using VHDL (if …elsif …elsif…else sentence ) meet problem
Matrix_YL
HI all
I meet a weird thing in my design when I want to implement a state machine by use ( if …elsif…elsif…else)
when  Waiting =>
          if     RNW='1' then
              state_next<=Receive;
          elsif  Finish = '1' then
              state_next<=Finish;
          elsif   Failure<='1' then
	        state_next<=Failure;
          else
	        state_next<=Waiting;
          end if;
when RNW=1 ModelSim show that logic works fine then state_next will be Recieve. but when RNW=0 the logic will take no account of Finish Failure value and state_next will be Failure.for example Failure =0 and Finish =1 ModelSim will show the state_next will be Failure
now I wondered use if …elsif…elsif…else sentence will meet some problem .
Can you tell me why this would be happen ? any suggestion to substitute this my problem code .
thx in advance
Re: using VHDL (if …elsif …elsif…else sentence ) meet probl
"waitig、"finish"、"failure"、"receive" are states of the finite state machine,but why do you use some of them as the infering condition in the program,it may well be some problems here. as i see, in the diagram of the machine, the condition "finish" is just a signal or global variable rather than infering condition,it is not the same matter.it is my idea,maybe it is also wrong, but it is hoped that it will give you an idea to correct it.
in the if else statement, it also sometimes problem for the complier when two or more conditions are tru, you might want to think again
when Waiting =>
if RNW='1' then
state_next<=Finish;
else
end if;
i guess this should be Failure='1' only
maybe this caused a problem
    Matrix_YL
when  Waiting =>
          if     RNW='1' then
              state_next<=Finish;
--          elsif   Failure<='1' then
--           state_next<=Failure;
          else
          end if;
if I comment two sentence above, if …elsif…else will be work fine but fail to go to state_next of Failure .
Can anyone tell me why if …elsif…elsif …else will make mistake however if …elsif…else will not ? how can I solve my problem ?
thx in advance
First you need to use the correct condition.
Please note that you are testing if Failure is less than or equal to '1', which is always true. Your state machine will never be in the Waiting state for more than one cycle.
    Matrix_YL
Why ? Can you make it more clear ?What should I do ? or give me some examples pls? how did I write my code to implement what I want ?
thx in advance
to Matrix_XL:
what should happen when ALL thre conditions are true?
Re: using VHDL (if &#8230;elsif &#8230;elsif&#82
Matrix_YL said:
when  Waiting =>
          if     RNW='1' then
              state_next<=Finish;
          else
          end if;
thx in advance
Just correct your code in this manner -
when  Waiting =>
          if     RNW='1' then
              state_next<=Finish;
          elsif   Failure = '1' then -- but NOT:  elsif   Failure <= '1' then
          else
          end if;
salma ali bakr has already point you to this mistake.
Added after 3 minutes:
<= - is not "less or equal" operator. It is a signal assignment operator in VHDL.
Added after 5 minutes:
Iouri said:
to Matrix_XL:
When all conditions are TRUE, only first will be processed, because if/elsif/else construction always present a priority structure.
    Matrix_YL
Hi all
I knew what's wrong with my FSM but I don't know how to solve it. Anyone can give me correct code to solve my problem.
thx in advance
You cannot embed an assignment within an expression. In the context of an expression, <= is "less or equal".
Hi all
Thank you all for your patience !I haven't notice exist
Failure <='1'
in my design . It's my mistakes ! Maybe something make me can't concentrate on my design !
now I am clear !!
u dont use if..elsif.....
use case thats better
because
if..elsif.. leads to prirority.... first case is considered first...
use case statement.. then no pripority comes...
Regards
Shankar
seeeee matrix...i was the first one to tell u about ur tiny mistake....
thanks for the points of the HELPED ME button u pushed...
take care,
Salma:D
