sheraz.pervaiz
Member level 4
why we need a dual supply in analog and mixed signal circuits?
Thanx
Thanx
because there are signals that are positive and negative like voice, we modulate them for example in AM or FM, wich carriers are alternanting voltage. In order to operate with negative voltages you must supply the transistors or IC with negative voltage.why we need a dual supply in analog and mixed signal circuits?
