kpatrick
I have to use a monostable multivibrator without an ic, because I only have 3V and ground as power supply.
I have a comparator, which i want to use as an input for the monostable multivibrator . So the monostable multivibrator should increase the time duration of the comparator.
As far as i know i have to use two transistors, three resistors and one capacity. I have seen the standard picture, but i do not know how i should use this circuit with the comparator. Or should i connect the signal of the comparator over a resistor with the first transistor, and i get the output at the second one?
Best Regards,
Patrick
Best Regards,
Patrick
