How to display and write 4 component jpeg to 3 component bmp
amith
Member level 2
jpeg
Hi All,
I have a 4 component jpeg image , if it is a 4 component i should assume it
a cmyk image or in any other format ,after decoding four component jpeg image how do i display it, to write in to bmp/png/ it requireis only 3 components (RGB).how do i do that .
amith
Re: jpeg
hey,
you have C,M,Y,K conversion methods, i hope this will work out.
C' = (C*(1-K)+K) R = (1 - C') * range
M' = (M*(1-K)+K) G = (1 - M') * range
Y' = (Y*(1-K)+K) B = (1 - Y') * range
The range is the difference between the minimum and the maximum value of R or G or B. usually it will be 255
with regards,
sathish kumar
Re: jpeg
Hi satish ,
Thanks for your reply , thing is that in my test image there four componets , but there is no adobe marker present in it ,i read in net that the cmyk images consist of adobe marker , is my understanding is correct , in this cas how i can i procedure with that jpeg image .
amith
Re: jpeg
hi amith,
All CMYK JPEG from adobe contains the adobe marker which means that, the image is inverted what you need to do is just invert i.e, 255-x. What you need to do is, if the adobe marker is present do the inverting operation on your own if not just do the convertion. I don't have experiance on it, you just try.
with regards
sathish kumar
Re: jpeg
good,i have the same problem
