Measure static power, dynamic power and leakage power ?
hoangthanhtung
Full Member level 3
How can I measure static power, dynamic power and leakage power seperately by using Affirma Analog Circuit Design Env. (Simulator : Spectre) ?
What is the circuit for which you want to measure the static, dynamic and leakage powers.
The static current is got when the circuit is ON and the dynamic current is when the output is making a transition and the leakage power when he circuit is off. Power = Current X Voltage.
My circuit is very large (wavelet chip) and I want to measure static power, dynamic power and leakage power seperately ?
Is there any efficient method to do that ?
How about the chip? If your chip is digital and no analog cells, the static power is nearly the same as leakage power.
