How do I automate or create a script in CST to postprocess some CST s-parameters?
kelvchan
Member level 3
Hi, may I know how do I automate or create a script in CST to postprocess some CST s-parameters? After simulating a two port structure, I wish to obtain an odd and even mode impedance by virtue of calculating S11-S12 and S11+S12 to obtain the respective impedances. Could someone direct me on this? Thank you.
Re: CST Script
Unfortunately, I can only relate (and not really help you) since i'm facing a similar problem.
If you are using a parametric sweep, then you can add a watch called : "User defined" which requires programming a special code in VBA macro. I have studied some CST examples and wrote a code by myself.
If its a single calculation, I'd suggest you export the S-parameters and post process them in Matlab or any other technical editor.
Regards,
P.
Re: CST Script
Hi kelvchan:
Have you looked through the Results Templates? There are many 0D and 1D operations that can be performed automatically during a parameter sweep on just about any CST result. The Results Templates in the Studio 2006 suites are pretty comprehensive.
--Max
Re: CST Script
Hi, thanks for the tip but my version is still at version 5.0.
Re: CST Script
Create a Result1D object and load the "^a1(1)1(1).sig" file. (S11)
Do the same for the "^a1(1)2(1).sig" file. (S12)
Then you can do a .add/.subtract or process to get the result and then save or addtoresultree.
Hope this helps.
CST Script
anyones have some totourial about cst scripting
Anyone know how to extract the Q-Value from the \Tables\0D Results\ folder? I use Q1=invoke(mws, 'SelectTreeItem','Tables\0D Results\Q-Value-h-field (f=resf)') but it does not give me the q-value that is calculated from the simulation. I get Q1 = 1. Please help.
Re: CST Script
Hallo.
Can you please tell me how can i see the .sig files in the 'Results' file ? I can't see them in the 'Result' file even if i see the s11 plot after the simulation? This problem appears only in CST 2011. When i simulate with 2008 version i can see them.
Thank you
