help needed in interfacing ADC0804 and HY62256(S-ram)at89c52
vinash
Member level 2
I have tried to interface ADC0804 and HY62256(S-ram) to AT89C52 microcontroller. The whole idea is to do an A/D conversion using ADC 0804 and than storing the data input to the SRAM. The code that i had developed is below for reference. It does not seem to work. (
1. Firstly even when i do not give an input signal to the ADC, the LED switches on
2. The LED switches on and than off (I suppose indicating that the S-ram has attained the required address)
3. The display always indicates 0; even though there is input signal in the ADC.
#include <reg52.h>
void delay(void);
unsigned char xdata * data addr = 0x0000; // declares a pointer staring from external memory address of 0x0000
sbit WRITE=P3^0; // defining the WR and INTR pins
sbit INTR=P3^2 ;// The INTR pin is connected to the INTO pin, so that whenever it goes low, it cause an interrupt
sbit READ=P3^3; //This is the READ pin ( for ADC)
sbit LED=P3^1;
sbit BLANK=P3^5; // I am using HP 5082-7340 (display) and the display blanks when this pin goes high
unsigned int advalue,value,j,converted,k;
scanled (); // to display the ADC value on HP 5082-7340 display
void main(void){
while(1) {
WRITE=0; // AD conversion;
WRITE=1;
while(INTR==1);
delay();
BLANK=1;
P1=0xFF; // declaring P1 as input data after A/D conversion
READ=0;
advalue=P1; // assigning the input bits (A/D bits) to advalue
READ=1;
if(addr<=0x0014) /* keep on storing the 8 bit values obtained from the ADC in address starting from 0x0000 till
the S-RAM stores data till the address reaches 0x0014 */
{LED=1; // to check whether there is any conversion (by toggling the LED)
*addr++ =advalue; // to store the values into the address
LED=0;
scanled(); // to display the input signal value on an adc
delay();
} //to check whether there is any conversion
else{
LED=1;
delay();
scanled()
unsigned int a[10]={0xE0,0xF0,0xE1,0xF1,0xE2,0xF2,0xE3,0xF3,0xE4,0xF4}; // Configuration for display from 0-9
P1=0x00; // declare P1 as output
BLANK=0; // The Blank is made low so that the HP display shows numbers
converted=(*addr)*(5/256); // Convert the ADC value obtained so that the input signal is between 0-5V;
P1=a[converted%10]; // Display the value on Port1;
for(j=0;j<20000;j++);
void delay (void) // Delay function using Timer 0 for 50ms.
TMOD &=0xF0;
TMOD |=0x01;
ET0 =0;
TH0 =0x3C;
TL0 =0xB0;
TF0 =0;
TR0 =1;
while(TF0==0);
TR0=0;
Could someone please tell me if there is anything wrong with my code. Thank you.
I have given example for interfacing ADC0804 with parallel port of computer in C. So i think that will help you. I used free running mode. For more details see my parallel port book
MY EXPERIENCE IN PARALLEL PORT INTERFACING
you can get it from yahoo group-booksbybibin
h**p://groups.yahoo.com/group/booksbybibin/
