+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Newbie level 2
    Points: 1,277, Level: 8
    Join Date
    Nov 2005
    Posts
    Points
    1,277
    Level
    8
    what kind of software support ATMEL's JTAGICE?
    I have been given a JTAGICE from a friend and need some tip about compilers that supports JTAGICE. I know AVR STUDIO from ATMEL supports it but is there others with a C-compiler and an easy interface?
    •   Alt15th November 2005, 14:28
      advertising
  2. #2
    Super Member
    Points: 3,669, Level: 14
    Join Date
    Jan 2002
    Posts
    198
    Points
    3,669
    Level
    14
    IAR. Check the www.iar.com site for more info.
    •   Alt15th November 2005, 17:33
      advertising
  3. #3
    Full Member level 5
    Points: 3,353, Level: 13
    dipal_z's Avatar
    Join Date
    Apr 2005
    India
    Posts
    278
    Points
    3,353
    Level
    13
    Winavr is GCC port for Atmel AVR processors and it support debugging using JTAGICE but you still have to use AVR STUDIO for debugging code compiled with Winavr.
    1 members found this post helpful.
    •   Alt16th November 2005, 07:20
      advertising
  4. #4
    Full Member level 4
    Points: 3,146, Level: 13
    Join Date
    Dec 2004
    Posts
    239
    Points
    3,146
    Level
    13
    WinAVR distribution contains also the avarice-gdb-insight toolchain...
  5. #5
    Newbie level 2
    Join Date
    Nov 2005
    Posts
    Points
    1,277
    Level
    8
    Re: what kind of software support ATMEL's JTAGICE?
    Thanks folks!
    It seem to me i have a cheap choice and a expensive one. IAR is the expensive one. Winavr and avrstudio 4 is a little more complex but as cheep as it can be.
    I have also found imagecraft V7 (http://www.imagecraft.com) may support jtagice with avrstudio, same as above. Codevision (http://www.hpinfotech.ro) also have some limited support if i understand it correct.
    It seem to be more educationg anyhow to install Winavr. It may take a while to get continious developed tools to work but it may be worth it.
    /BeO
