Clock divider by 3 with 50% duty cycle?
davyzhu
Advanced Member level 1
oriental
clock divider by 3
Hi all,
How to Build a Clock divider by 3 with 50% duty cycle?
Input and output are listed below.
Clkin
__--__--__--__--__--__--
Clkout
______------______------
Any suggestions will be appreciated!
Best regards,
Davy
divide by 3 clock
First you have to double input frequency, and then divide it by 3.
then divide it by 2 to produce 50% duty.
for doubling input frequency simply put one delay (such as RC, or buffer gates)
for example 20nS, then XOR input frequency and delayed one, you get 2x multiplayer.
Davood Amerion
clock dividers made easy
Below is a circuit that divides incomming wave by 3 with 50% duty cycle ..
Reards,
IanP
clock divide by 3
I prefer Davood Amerion's method,
that would avoid clock glitching.
hi,IanP
can you assure there is no glitching in your combinational source of clock?
    davyzhu
divider by 3
It looks glitch-free. It's from a Xilinx app note "Unusual Clock Dividers":
The author repeatedly warns about possible simulator problems, but I have no problem simulating it in Verilog/ModelSim.
Both of these methods assume the input clock has 50% duty cycle, or else the output won't be symmetrical.
divide clock by 3
Hi Davood,
Thank you :)
What's "and then divide it by 3." mean?
Is it 50% duty?
Best regards,
Davy
divide by 3 circuit with 50 duty cycle
The "divide it by 3" can be just an ordinary two-bit counter that goes 0,1,2,0,1,2,...
After doing those steps, you would have signals like this. For the output to have 50% duty cycle, the input clock must also have 50% duty cycle.
divide by 3 with 50 duty cycle
Davood Amerion
why dont we divide by 3 directly insted of multipliying by2, then divide by 3, and then divide by 2.
clock divided by 3
Dear davyzhu,
I think the echo47's answer is complete.
Dear anjali
Because when we directly divide by 3 we can't get 50% duty (insted we get 33.3% duty)
clock divide 3
hai davood, we can get 50% duty cycle even by directly DIVIDE BY 3. by using 2 couters (one posedge triggered & one negedge triggered) & once total count equals 3, output clk need to be toggled. i followed int his way, instead of multiplying by 2, then divide by 3, then divide by 2.
divider 3
Hi echo47,
Why not go directly from "XOR" to "Divide by 6"?
Best regards,
Davy
unusual clock dividers
oh, thanks to echo47 ,
your design is glitching free,the combinational based latch is great!
clock dividers
You guys are giving my too much credit. ;)
I drew the timing diagram to illustrate the suggestion by Davood Amerion.
The latch-based design was suggest by IanP. The design is from "Unusual Clock Dividers" by a Xilinx applications engineer.
davyzhu, an ordinary divide-by-6 counter that goes 0,1,2,3,4,5,0,1,2,3,4,5,... wouldn't have 50% duty cycle. By separating the counter into divide-by-3 and divide-by-2, you get 50%. (Actually, this still is a divide-by-6 counter, but with a funny count sequence.)
Someone asked me which program I used to draw that timing diagram. It's just lines drawn with a CAD program. I used good old OrCAD SDT for DOS. I still use it for large project schematics. I prefer it over all the modern tools.
esnips + clock dividers made easy
Here is one more ckt in verilog!!
module clk_div3(clk,clk_out);
   input clk;
   output      clk_out;
   reg [1:0]   cnt_p, cnt_n;
   wire [1:0]   cnt_p_nx, cnt_n_nx;
   initial begin
      cnt_p = 2'b11;
      cnt_n = 2'b11;
   end
   assign clk_out = cnt_p[0] | cnt_n[0];
   assign cnt_p_nx = {cnt_p[0],~(cnt_p[0] | cnt_p[1])};
   assign cnt_n_nx = {cnt_n[0],~(cnt_n[0] | cnt_n[1])};
   always @(posedge clk)
     cnt_p <= cnt_p_nx;
   always @(negedge clk)
     cnt_n <= cnt_n_nx;
endmodule // clk_div3
You can add reset signal to remove the initial statement!
    V
    sanju_
    boko_dyuzov
2/3 divider 50% duty
CLOCK DIVIDERS MADE EASY
    davyzhu
verilog clock divider 50 duty cycle
Thanks. it is useful for me
   input clk;
   output      clk_out;
   initial begin
      cnt_p = 2'b11;
      cnt_n = 2'b11;
   end
     cnt_p <= cnt_p_nx;
     cnt_n <= cnt_n_nx;
    davyzhu
clock divided by 3 circuit
Check this paper as well
Maybe it is the same as the one by tut.
    davyzhu
xilinx application note digital clock divider
If simplicity of design strikes you, then here's a solution.
If i have a 3 bit ring counter preloaded with a value 001, then I tap the output from any point, I'd have a divide-by-three 33% duty cycle output.
If i have another 3 bit-ring counter preloaded with same value 001, but clocked on the negative edge of the clock, I'd have another divide-by-three 33% duty cycle output with phase shift of 90 degree wrt the first output.
I OR these two outputs and I get a divide-by-three 50% duty cycle output. Am i right?
clock dividers made easy.pdf
Yes that would give a 50% duty cycle (assuming the input clock is square), however I wouldn't say a six-flop solution is "simplicity of design". ;)
By the way, if those two counters should ever fall out of sync (for example by a noise glitch or cosmic ray hit), then they would stay that way forever. I recommend using self-synchronizing logic wherever possible.
Reactions: sdeora
    sdeora
clk divider 3
Just so that i understand the comment. Is Davood Amerion's solution the best available? Aren't there any issues in that circuit to produce 2x frequency square waves from a XOR gate and delay elements? Isn't designing the delay element more involved than putting six standard flops? I ask this so that i get the perspective...
