help!help!Relation between Baud rate and sampling rate
yoyobaby
relation between sampliing rate and baud rate
HELP!!!
what is the difference between Baud rate and sampling rate???
can Baud rates change to sampling rates???or sampling rates change to Baud rates???
is it have a equation to calculate it???
thank you very much!!!
relation between sampling and baud rate
baud is the signalling rate and not the data rate..
like in some coding schemes...(ASK ,PSK) one signal corresponds to more than a bit
thus data rate === baud rate * no of bits used in the scheme
    yoyobaby
baud rate sampling rate same
Baud reat means how much the the signal is changed from logic high to logic low
in one second
e.g when we say baud rate = 1000 thats mean the signal is changed from high to low 1000 time in the second
regards
    yoyobaby
Sampling rate, refer to the serial receiver clock, that sample the incoming signal in order to decide when a transition, in the incoming stream, occured. Usually, it's 8 to 16 times higher then the baud rate.
    yoyobaby
