muhammadali007
Newbie level 6
transformer secondary sheet winding
I am trying to rewind an old transformer (EI type) taken from a 3000W voltage stabilizer.. i will use it in dc-ac inverter 12VDC to 220-240VAC (50Hz).. Please tell me all the specifications i.e. no. of turns in primary and secondary, the dimensions of the core (if relevant!! current dimesions are given below), diameter of the winding coil etc.. it will be a center tapped transformer with 2 primary windings for switching purpose.. and 1 secondary winding.. however.. it might not be used at full 100% load i.e. 3000W loads.. loads will be around 1500W.. and i'll be using 12V 200AH battery.. or 2 batteries of same specifications i.e. 12V 200AH each!
Any ideas for making an efficient transformer which could work properly and not heat up?? Should i use 3000VA transformer? or would it be more efficient to use 1500VA transformer?? however, need might arise to use it for loads of upto 3000W!
Dimensions
length of 'I' = 10.5 cm
width of 'I' = 1.7 cm
Thickness of the pile/core = 5.5 cm
length of 'E' = 10.5 cm
width of 'E' = 7.7 cm
width of the middle section of E on which coils are wound = 3.5 cm
Dimensions
