pads designer, pads logic and schematic part of the pads?
seyyah
Advanced Member level 2
pads logic
These tools have limited 2d drawing capability and makes difficult to create own libraries and adding 2d drawings on the schematic. Also editing functionality is very bad. Does mentor or other pcb software has better schematic drawing software which can work with pads layout or export to power logic pads designer etc. I don't understand why mentor doesn't add some functionality to these types of thing which improves visuality. I like powerpcb but i have trouble some with their schematic programs. Also pads libraries are limited in comparison to most of the other software packages even the simple ones.
pads logic library
U can use the tool of mentor "schcvt.exe" to convert protel or orcad sch lib to power logic, or u can import dxf file to powerpcb and save as a library. then u can use it in power logic.
