gkats
Newbie level 3
pierce configuration
Hi all,
I am designing a crystal oscillator in parallel configuration at 28MHz.
(The series resonance of the crystal is at 28MHz).
When i connect the crystal equivalent circuit (LCR) to the oscillator
(consist of an inverter with a resistive feedback),
the circuit oscillates at much lower frequencies than the expected (28MHz).
The problem seems to be with the value of the feedback resistor.
It sould be high enough (more than 100 KOhms), but only when it drops down to some kOhms (5KOhms) the circuit oscillates near the crystal resonance freq.
Is this phenomena reasonable? Has to do also with the inverter?
Can you point me some references for crystal oscillator designs.
Thank you very much in advanced!!
Hi all,
