nvd
Full Member level 2
- Joined
- Jan 17, 2005
- Messages
- 129
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,298
- Location
- Solar System
- Activity points
- 1,219
Flicker Fusion Frequency
I designed a circuit using 555 timer. It flashed an LED using pulses. By changing the duty factor, its brightness changed. Provided that the frequency was greater than Flicker Fusion Frequency, how could it cause a change in the brightness as each pulse was turning it fully ON with maximum brightness?
