Interfacing 8051 with HT1621 LCD Driver
stinger-dk
Newbie level 1
ht1621
I am using AT89C51 to run a 24 seg, 4 com lcd using HT1621 driver. I am using C with Keil uVision.
Using the code below, all i get is 8 on segments. no matter what i write, those 8 segments will go on. rest of the segments will stay off... The segments which are on correspong to addresses 3, 4, 5 and 6 of HT1621.
Please also explain why are there 6 address lines when there are only 32 locations to be addressed?
I have used 11.059Mhz crystal for 89C51 so delays in nano seconds (for th1 and tsu1) are not possible. But i don't think they should be a problem. I have used 32.768KHz external crystral for HT1621.
All help will be greatly appreciated :D Thanks in advance!!
Here is the code:
#include <reg51.h>
//Interface with HT1621
sbit wr=P1^0;
sbit dt=P1^1;
sbit cs=P1^2;
sbit rd=P1^3;
int com_reg;          //Bits to be transferred is stored in com_reg
bit com_mode=0;       //Tells that commands are being transferred and not data
unsigned int mask=0x8000;
bit haha=0;
void delay (unsigned int j)
	unsigned int i=0;
	for(;i<j;i++);
void cs_pulse(void)
	cs=1;
	delay(1);	//For t(CS)
	cs=0;
void lcd_wr(void)
	//This will write data to HT1621
	rd=1;	//HT1621 clocks data out at falling edge of rd clock
	wr=1;	//Initializing rd and wr. rd will remain 1 forever.
	cs_pulse();
	delay(1);	//For t(su1)
	mask=0x8000;
	if(com_mode==0)
		while(mask!=0x0004)
			wr=0;
			delay(1);	//For t(CLK)
			haha=com_reg & mask;
			dt=haha;
			delay(1);
			wr=1;
			delay(2);
			mask>>=1;
	else if(com_mode==1)
		while(mask!=0x0008)
			wr=0;
			dt=haha;
			delay(1);
			wr=1;
			delay(2);
			mask>>=1;
	delay(1);	//For t(h1)
	cs=1;
void main()
	//Initialization
	dt=0;
	delay(10000);
	com_mode=1;
	com_reg=0x8020;		//SYS EN
	lcd_wr();
	com_reg=0x8560;		//BIAS 1/3 with 4 commons
	lcd_wr();
	com_reg=0x8090;		//TIMER DIS
	lcd_wr();
	com_reg=0x80A0;		//WDT DIS
	lcd_wr();
	com_reg=0x8280;		//XTAL 32K
	lcd_wr();
	com_reg=0x8060;		//LCD ON
	lcd_wr();
	com_mode=0;
 	//Following code will put switch segments corresponding to addresses 1 and 2 of ht1621 on.
   com_reg=0xA0F8;
	lcd_wr();
	com_reg=0xA178;
	lcd_wr();
