What is the different of these resistors?
Question
Member level 5
silicided resistor
In TSMC PDK, there are many kinds of resistors.
rnplus - N+ diffused resistor w/o salicide
rpplus - P+ diffused resistor w/o salicide
rnlplus - N+ diffused resistor w/i salicide
rplplus - P+ diffused resistor w/i salicide
rnwell - N-Well resistor under STI
rnwod - N-Well resistor under OD
rnlpoly - N+ Poly resistor w/salicide
rplpoly - P+ Poly resistor w/salicide
rnhpoly - N+ Poly resistor w/o salicide
rphpoly - P+ Poly resistor w/o salicide
rphripoly - P- Poly HRI resistor w/o salicide, with MM model
what are 'w/o salicide' and 'w/i salicide' ?
what is the different of 'poly' and 'diffused' res, 'w/o salicide' and 'w/i salicide' res?
Thanks a lot!!!
hri resistor
'with' and 'without'?
salicide will lower the sheet res of the materials.
silicide resistor
Diffusion resistors are made with n- or p- diffusions in the substrate. Poly resistors are made with the poly layer. Poly resistors tend to have much higher sheet resistivity than diffusion resistors.
salicide resistor
Maybe , the common poly sheet resistor is smaller than the diffusion resistor.
and , from the accuracy aspect, the poly resistor is beteer than the diffusion resistor.
and for the temperatur coeffecient, the voltage coeffecient, the two types resistor is not the same. Generally, in most aspects, the poly resistor is beter than diffusion with exception of silicon Area.
n-well resistor
The resistors are made from doped polysilicon (all poly) or different diffusions in the process. The three diffusions that are used for resistors are N+, P+, and N-Well. The N+ and P+ diffusions are used for the drain/source of NChannel/PChannel transistors respectively. The N-well is the body of a PMOS transistor. The N+ and P+ are shallow lower sheet resistance resistors. They would be best for lower value of resistors. the N-Well is a deeper junction and would be better for middle values of resistors.
The addition of silicide to all of these effictively puts a metalic layer over the resistor significantly reducing the sheet resistance. Silicide is made by reacting a metal with exposed silicon forming a silicide. There are a number of metals that will form a silicide with silicon. TSMC could tell you which one they are using.
Silicided resistors would be ones that need small resistance values.
Dr. Prof
salicided resistor
Addtional Mask is necessary for HR type.
n well resistor
Temperature changes the characteristics of silicon; and the number of carriers available for conduction. Think resistor!
Now if they have salicided these N+ and P+ areas, the resistance becomes smaller since they are introducing metal, but it is like creating an alloy, and the temperature doesn't affect is so much any longer.
Still, poly resistors are better-behaved with temperature.
poly resistors
what are the advantages and disadvantages between
Thanks
Bhanu
silicide poly resistor
and who know the parasitic capacitor of these resistors?
