Can I program ATMega8, 16 and 32 with STK200 cable?
Jack// ani
Advanced Member level 3
Hi all,
Thanks
stk500 atmega168 schematic
Hi ,
yes you can ,
you can use 'Pony Prog' programmer :
stk200 stk500 differences
I thought it needs STK500, BTW what is advantage of STK500 over STK200?
programming atmega88 with stk500
Hi ,
I don't know the difference between STK500 and STK200 ,
you can download the programmer that i use.
stk500 atmega88 programming
YOU CAN TAKE A LOOK AT THIS SITE FOR STK200 TYPE PROGRAMER.
I HAVE MADE IT USING SMD PARTS. IF YOU NEED ARTWORK I AM READY TO PUT IT OUT HERE.
PLEASE REFER TO THE MCU PROGRAMABLE WITH THIS
programing atmega8 stk500
:D schematic pdf for stk-500 atmel
Programming ATMega
may be STK200 is older one and then STK500 is newer one
