How can I drive a weak zero in Verilog?
vivek
Member level 4
hi
how can i drive a weak zero in verilog? In VHDL it can be easily done using std_logic. Also how will be this weak zero be realised in real circuit?
verilog tri0
Give here ur VHDL example for weak zero. I will write equivalent verilog for that!
verilog syntax weak
hi
in VHDL weak zero is one of the values which can be taken up by the std_logic data type. in verilog no such data type is there. then how can we model
weak zero?
verilog weak 0
In VHDL for weak 0 we have 'H' whoes equivalent in Verilog is tri0
    vivek
weak 0 in verilog
weak zero will be realized by weak driver,
for example, in TSMC libs, X4 strongest driver,
X1, X2, X3 moderate driver.
XL weakest driver.
vivek said:
hi
weak pulldown in verilog
Hi, power-twq
I think that you maybe make a mistake. The lib of X1, X2, X3 ... are only for drive ability.
In each process lib, there are some pad for weak output, such as pull-up pads and pull-down pads.
You can request those datasheet from TSMC or SIMC etc.
Good Luck
