+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Junior Member level 3
    Points: 1,519, Level: 8
    Join Date
    May 2005
    Posts
    30
    Points
    1,519
    Level
    8
    at28c256 time for erase
    How i interface EEPROM (AT28C256) with 8051 microcontroller and i how erase this EEPROM either using GENIUS NSP universal programmer or any other eassy method.
    •   Alt29th May 2005, 06:56
      advertising
  2. #2
    Advanced Member level 5
    Points: 74,061, Level: 66
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    Re: interfacing EEPROM (AT28C256) with 8051 microcontroller
    8051 uses multiplexed address/data bus so you will have to use 74LS373 or similar to latch the lower 8 address lines.
    Example on how to do this you can find here:
    http://www.cs.ucr.edu/~vahid/courses/122a_f99/ch6.pdf
    You can use another external ROM/EPROM and write a short program to erase the EEProm, which,as in the above example, can be connected in the same way to the system as first EPROM + , say, pin P1.0 to select which of them should be used to read program.
    Try "software chip erase" option from the Atmel website:
    h**p://www.atmel-grenoble.com/dyn/products/app_notes.asp?family_id=638&part_id=1904
    Regards,
    IanP
    •   Alt29th May 2005, 07:30
      advertising
  3. #3
    Points: 11,875, Level: 26
    bobcat1's Avatar
    Join Date
    Jul 2002
    Posts
    Points
    11,875
    Level
    26
    Hi
    Check philips site for XA app note there is one app note who describe connection of the XA to parallel FLASH memory
    There is also a software for programming & writing the flash
    The philips XA hardware is the same as the 8051 hardware!
    All the best
    Bobi
