Invert the vector in matlab? Why not y(5:1)=x(1:5)?
davyzhu
Advanced Member level 1
oriental
matlab invert vector
How to invert the vector?
For example,
x=[1 2 3 4 5];
And I want y = [5 4 3 2 1];
But y(5:1)=x(1:5) seems cannot do that work.
Any suggestions will be appreciated!
Davy
matlab vektor invertieren
It is very simple.
If you have a matrix x=[1 2 3 4 5]; run the following script:
for i=1:size(x,2)
y(size(x,2)-i+1)=x(i);
end
and you will get the y you want. The function size() returns the size of the matrix x.
Regards
Flo
invert vector matlab
This is what you where trying to do.
x=[1 2 3 4 5];
y=x(5:-1:1)
You have to study how Matlab handles matrices and indexes. It
a little different from other standard methods.
Peace
matlab invert
about your question "Why not y(5,1)=x(1,5)?"
In Matlab y(m,n) means the element in the mth row and nth column.
i.e if you have this script
x=[1 2 3 4 5];
y(5,1)=x(1,5);
will give you a vector of one column and 5 rows
y=[0
5]
and it will assign all the remaining elements to zero as shown above.
I think that you will need a script as the one mentioned by gfloros.
or you can define it exlicitly
y=[5:-1:1] which means the starting element is 5 and the step is -1 till you reach the final element which is 1
Matlab is primarily based on Matrices and vectors, to get more help I think the Matlab getting started tutorial is the best refrence for that topic
