What is the cause of gain expansion in power amplifier?
bouchy
USA
Gain expension
I was wendering what is the cause of gain expansion in power amplifier.
Thanks
Bouchy
Re: Gain expension
yes i am also same question in my mind,why do we always confine ourselves with only its effiency
Re: Gain expension
If we will use small signal, then the non linear effect will be much less the in large signal. So in power amp in nature you have to use large signal to create power, then you will get the non linear effect that you have in transistors/ power Fet etc...
Regards
Moda
