Need coaxial cable design for HFSS simulation
Catalyst
Full Member level 3
Hello everyone,
I am starting on an antenna related simulation using HFSS 9.2.
1 - I was wondering if anyone has a simple coaxial cable desing that I can import into my project to feed the antenna?
2 - For an antenna simulation should i use a driven terminal solution setup?
Thank you
Cat
hfss coaxial cable
Catalyst said:
Hello everyone,
Thank you
Cat
this is really simple :)
coaxial cable hfss
We ran a complete set of test on HFSS. check the zipped pdf. It's written in german though. Just ask if you have questions.
Hope it helps.
D.
coaxial cable in hfss
thank you very much
    V
