Saving Leading Zero HEX into String Arduino
DianWardiana
Junior Member level 3
I'm using Arduino Nano to read RFID card. I'm using RC522 as RFID Reader.
I have problem when i try to save RFID card value with leading zero into string. The leading zero is not saved into string.
Here is my code:
#include <SPI.h>
#include <MFRC522.h>
#include <stdlib.h>
#define RST_PIN         9
#define SS_PIN          10
String inStringHex = "";
MFRC522 mfrc522(SS_PIN, RST_PIN);
void setup() {
  Serial.begin(9600);
  SPI.begin();
  mfrc522.PCD_Init();
void loop() {
  // Look for new cards
  if (mfrc522.PICC_IsNewCardPresent() && mfrc522.PICC_ReadCardSerial())
    //Serial.print("Card UID:");
    for (byte i = 0; i < 4; i++) {
      Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? "0" : "");
      Serial.print(mfrc522.uid.uidByte[i], HEX);
      inStringHex += String(mfrc522.uid.uidByte[i], HEX);
    Serial.println();
    Serial.println(F("Hex normal"));
    Serial.print(inStringHex);
    Serial.println();
    Serial.println();
    inStringHex = "";
    delay(5000);
Here is the result in Serial monitor:
https://imgur.com/a/0mbxlDH
What i want is the String under "Hex normal" would be "04292e5a" not "4292e5a"
Thank You.
You have to parse all special characters and add the scape comand \ right before them, as for example by replacing 0 with \0. This is necessary because many non-alphanumeric characters are used by the compiler as delimiters, therefore you need to instruct compiler to treat it as a bare character.
