OffTheShelf Hysteretic controller required for LED driver
T
treez
Hello,
We are doing a 6W Constant off time controlled Buckboost LED driver…
(schematic and LTspice simulation attached).
Vin = 18-137.5VDC
VLEDs = 45V
Power = 6W
Constant off time control (off time = 3.5us)
No electrolytic capacitors allowed (no large films either)
Note: It actually has to work down to Vin = 8V , but only at 1.2W for that case.
The wide Vin range means constant off time control is needed for control. The problem is, there are virtually no offtheshelf constant-off-time controllers available. (except the HV9910B, but that has no internal error amplifier, and only a weak gate drive).
Therefore, we had to use a “hacked” UCC28C43 controller.
The problem is that the controller, with all the auxiliary components needed with it, take up a lot of space, and space is very constrained. The PCB is only 22mm by 200mm. We are only allowed double sided PCB, no more layers. Driver components go on the bottom, LEDs on top.
The biggest problem, is that our lack of space means that we can’t fit much input capacitance on the PCB. We only have 2uF of ceramic input capacitance, -that’s all we could fit on. The result is that there is fairly significant ripple in the input current. This may fail EMC, (though we havent had the standard limits given to us yet).
Another point is that in some products, several of these 6W PCBs will be used together…..and as you know, this means that there will be beat frequencies as they interact with each other. This could well occur at the resonant frequency of the EMC input filter, and that would mean unwanted resonance there.
What we really need is a “dual threshold hysteretic controller”.-By that I mean a controller which allows one to set a maximum and minimum threshold for power inductor current….(and these would be varied ‘on the fly’ by a micro)…we could then simply get a micro to read the actual LED current, and then simply increment the thresholds gradually until the desired LED current was achieved.
Do you know if such a controller exists?
  • Buckboost LED driver 6W.txt
  • Buckboost LED driver 6W.pdf
12F675 has EEPROM and ADC, why is the digital pot needed as well?
Brian.
Reactions: treez
    T
Thanks, We need digital pot so we can set the reference voltage to the error amplifier.
This is because when Vin is 8-14VDC, we need only 1.2W of output.
When Vin is 14-18V, we need 4.5W of output.
If you use a 12F683 instead of the 12F675 (they are the same price) you can eliminate the digital pot completely and save costs and board space. The '683 can generate a precision DC output and has EEPROM to store the reference voltage.
Brian.
Reactions: treez
    T
A TLC555 could possibly do this, it has two thresholds - one of which can be pulled (down) to narrow the band and a good clean signal out of pin 3.
We have used these as controllers on all manner of simple power converters, a 2nd TLC555 could be used as a one shot for your constant off time...
Reactions: treez
    T
I agree that there is no need for a digital pot or a DAC.
A microcontroller with built in ADC or built in analog comparator does the job...a 555 or any dual comparator...
Two open collector outputs can control the feedback to adjust for 1.2W and 4.5W.
Klaus
Reactions: treez
    T
