Less than 2 connection and floating. please help
karau
Newbie level 1
Code dot - [expand]
8
9
10
11
12
13
14
15
16
17
18
**** INCLUDING SCHEMATIC1.net ****
* source CLASSPORJECT2
V_V1         N00245 0 DC 987
R_R1         N00245 N00252  1k
R_R2         N00309 N00252  3k
R_R4         0 N00309  2k
R_R5         N00281 N00252  6k
R_R6         N00309 N00281  6k
R_R7         0 N00281  1k
V_Vx         M_UN0001 M_UN0002 DC 50V
R_R8         N00763 N00770  10M TC=0,0
R_R9         N00770 0  8k TC=0,0
R_R10         N00770 N00774  7k TC=0,0
R_R11         N00774 0  10k TC=0,0
I_Ix         0 N00774 DC 20mA
**** RESUMING DCswp2.cir ****
.END
Code dot - [expand]
8
9
ERROR(ORPSIM-15141): Less than 2 connections at node M_UN0001.
ERROR(ORPSIM-15141): Less than 2 connections at node M_UN0002.
ERROR(ORPSIM-15141): Less than 2 connections at node N00763.
ERROR(ORPSIM-15142): Node M_UN0001 is floating
ERROR(ORPSIM-15142): Node M_UN0002 is floating
I'm not sure which program is producing this error but there appears to be more components in the net list than on the schematic. Can you show a scjhematic with the node numbers added to it?
Brian.
Yes, the netlist doesn't belong to the schematic circuit. Please come back with consistent data. Even if you don't fully understand SPICE netlists, you should see that the component designators must match the schematic.
The schematic however looks like Vx is placed off-grid, without connecting to wires, which most likely causes the error in this simulation schematic.
