Shift register, I have troubles when creating components please help!
7mod998
shift register , i have troubles when creating components please help!
mux code
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity mux is
Port ( A0,A1,A2,A3,S0,S1 : in STD_LOGIC;
IL : out STD_LOGIC);
end mux;
architecture Behavioral of mux is
signal s: std_logic_vector (1 downto 0 );
begin
S <= S1&S0;
with S select
IL <= A0 when "00",
A1 when "01",
A2 when "10",
A3 when "11",
'0' when others;
end Behavioral;
clk div code
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
library IEEE;
--library UNISIM;
entity clk_div is
 Port ( clk : in std_logic;
 clk2: out std_logic );
end clk_div;
architecture Behavioral of clk_div is
begin
process(clk)
 variable c : integer range 0 to 50000000:=0;
 begin
if(clk'event and clk='1')then
c:=c+1;
if(c=50000000) then c:=0; clk2<='0';
elsif (c=25000000) then clk2<='1';
elsif(c<25000000) then clk2<='0';
end if;
end if;
end process;
end Behavioral;
shift reg code
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
library IEEE;
--library UNISIM;
ENTITY shifter_unit is
PORT(clk, il, ir,sin : in std_logic;
s: in std_logic_vector (1 DOWNTO 0);
i : in std_logic_vector (3 DOWNTO 0);
q : out std_logic_vector (3 DOWNTO 0));
END shifter_unit;
ARCHITECTURE Behavioral of shifter_unit is
SIGNAL qtmp : std_logic_vector(3 DOWNTO 0);
BEGIN
q<=qtmp;
PROCESS(clk)
BEGIN
IF (clk = '1' AND clk'EVENT) THEN
CASE s IS
WHEN "00" => qtmp <= i;
WHEN "01" => qtmp<=sin&qtmp(3 downto 1);
WHEN "10" => qtmp<=qtmp(2 downto 0)&sin;
WHEN "11" => qtmp<=qtmp;
WHEN OTHERS => NULL;
END CASE;
END IF;
END PROCESS;
q <= qtmp;
end Behavioral;
final design
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
library IEEE;
--library UNISIM;
ENTITY final_design is
PORT(clk, c : in std_logic;
s: in std_logic_vector ( 3 DOWNTO 0);
A : in std_logic_vector (3 DOWNTO 0);
END final_design;
architecture Behavioral of final_design is
component mux is
end component;
component shifter_unit is
END component;
component clk_div is
end component;
signal il, ir, clk1 : std_logic;
begin
uo:mux port map (S(1),S(0),A(0),c,'0',A(3),il);
u1:mux port map (S(1),S(0),A(0),c,'0',A(3),ir);
u2:shifter_unit port map (clk1,il,ir,S(3 downto 2),A(3 downto 0),q(3 downto 0));
u3:clk_div port map(clk,clk1);
end Behavioral;
Re: shift register , i have troubles when creating components please help!
and whats the problem?
It doesn't look like all of your ports being assigned.
From Final Design:
From Shift Reg Code:
PORT(clk, il, ir,[B][COLOR="#FF0000"]sin[/COLOR] [/B]: in std_logic;
so what should i do ?:-(
maybe it's supposed to be connected to a top port of final_design or generated from a component that is currently missing from the design.
You need to learn how to ask questions if you expect more useful help. http://www.catb.org/esr/faqs/smart-questions.html
In situations like this, it's almost always a good idea to give the error message!
