Results 1 to 8 of 8
    Points: 1,090, Level: 7
    May 2013
    46
    1,090
    7
    Mixed signal voltage sources for generating waveform
    hi guys i have orcad pspice 17.2 and i need to do a simulation where i have turn on and off using diffrent logic signals so i need to be able to find a vsource in the library the waveform would be similar to what you might see in a logic timing diagram if some one could help
    •   Alt16th April 2018, 06:40
      advertising
    Points: 20,380, Level: 34
    barry's Avatar
    Mar 2005
    California, USA
    3,932
    20,380
    34
    Re: Mixed signal voltage sources for generating waveform
    Do you mean a pulse/squarewave source?
    May 2013
    46
    1,090
    7
    i mean like a digtal pulse waveform like a digital signal that is a repeating signal of these logic states (on,off,off,on,on) so like the picture i have attachedClick image for larger version.
Name:	my timing pulse.jpg
    •   Alt16th April 2018, 23:45
      advertising
    Points: 241,738, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,971
    241,738
    100
    It's not clear if our problem is specifying the signal sequence or converting it to an analog signal. Both topics are covered by the Pspice reference manual. For the latter problem, the default digital input device most likely does what you want.
    May 2013
    46
    1,090
    7
    problem is in finding a source in the library that would produce a digital waveform like the one i tried to draw attached to the forum. i know i can produce something like that with the stim1 part and its command 1 to 16 properties but i cant get it to repeat
    barry's Avatar
    Mar 2005
    California, USA
    3,932
    20,380
    34
    You could just take the brute force approach and sum three pulse sources to get your required periodic signal
    •   Alt17th April 2018, 14:41
      advertising
  7. #7
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,971
    241,738
    100
    I guess you didn't yet try PWL sources. They have repetition features.
  8. #8
    May 2013
    46
    1,090
    7
    how does picewiselinear
    work and how do you set it up and is that the best way to do it
