Results 1 to 10 of 10
    Full Member level 1
    Points: 2,329, Level: 11
    Jul 2008
    114
    2,329
    11
    High Speed Motion Sensor
    Hi. I want to detect a very high speed object via Sensor. Example a bullet shot. Sensing distance can be 30 Feet around. I know PIR Motion sensor but that will be slow for this application? Is there any other better option to detect fast motion?
    My main need is detect fast motion and capture photo by Camera via USB Command.
    Any advice please?
    Thanks in advance
    Points: 26,005, Level: 39
    andre_teprom's Avatar
    Nov 2006
    Brazil
    7,838
    26,005
    39
    Blog Entries
    Re: High Speed Motion Sensor
    What you need is just an optic barrier sensor, nothing more complex than that. At one side, a light emitter device and on the other side a photo-detector; It is assumed that there will be sufficient distance between the point of detection and the point of the image capture; It is also assumed that the camera you have chosen is adequate to deal with such object's speed and the effect of its movement during the sample period of the image in the vision sensor.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    Points: 241,412, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,891
    241,412
    100
    According to bullet speed in a 1000 m/s range, you need camera with µs aperture time for sharp imaging.
    Full Member level 1
    Jul 2008
    114
    2,329
    11
    Thanks all for reply. Yes, I am also thinking of laser sensor.
    My bullet example may not be a proper case. But in generally I wanted to detect faster motion objects. Just asking instead of PIR is there any other choices?
    Thanks.
    Nov 2006
    Brazil
    7,838
    26,005
    39
    Blog Entries
    Quote Originally Posted by sakibnaz View Post
    Did you read above replies? you've been informed that the type of detection by optical barrier is the one that seems to be the fastest you can achieve, and if that was not what you expected, at least let us know what aspect of that solution do not suit for your original question:
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,891
    241,412
    100
    A mid/far IR sensor like PIR would be used if you specifically want to detect thermal infrared radiation. It's not really clear how it's useful for your project. PIR sensors can be made with different bandwidth and respective detection speed, but thermal noise sets an upper limit depending on the object temperature.
  7. #7
    Points: 34,469, Level: 45
    7 years registered Created Blog entry Created Album pictures
    SunnySkyguy's Avatar
    Sep 2007
    Richmond Hill, ON, Canada
    6,667
    34,469
    45
    Blog Entries
    7
    You must define some specs:
    { object speed in m/ms, camera trigger latency and capture time, possible range offset for sensor trigger.}
    This defines the required light beam switch rise time or latency for laser beam interruption at a certain distance. in [us] = distance offset / speed/
    A good design question lists your overall requirements™ The best question deserves a better answer. ™
    ... Tony Stewart EE since 1975
  8. #8
    Full Member level 1
    Points: 656, Level: 5
    Apr 2017
    98
    656
    Thanks.
    An ordinary camera is a good motion sensor. You can use it and later process the images.
  9. #9
    Nov 2006
    Brazil
    7,838
    26,005
    39
    Blog Entries
    Quote Originally Posted by filip.amator View Post
    Not for that application:
  10. #10
    Full Member level 1
    Apr 2017
    98
    656
    Quote Originally Posted by andre_teprom View Post
    Think of all those movies with the bullet passing thought an apple/egg/can - the footage is usually taken by the high speed camera. Just one of the many examples:
    https://www.youtube.com/watch?v=8BIEBn-Uu6I
