47box
Newbie level 5
I'm having problems with code execution in Proteus.
The code has a delay time that is used to put the state of the output PORTB into 00000011 ( pin0 and pin1 "on") after the time set by the timer.
One time the button is pressed the output state is changed and after a delay of 2s the output state is automatically changed to (00000011).
The first stage the initial condition is set and after 2s automatically changed to 00000011 without the need to press the button.
After this stage the program will only respond with the button press, causing the output state to change (00000001) and after 2s (delay_loop call) it will return to state 00000011 automatically.
I finished the program after the button was pressed to determine the problem more easily. (after pressed ONCE the program goes to "rjmp PC")
The problems I'm having are:
* the program wait press a button.... button pressed >> goes to 00000001 ........then the delay_loop is called again (HERE looks like the delay_loop does not do nothing in Proteus, the output signal will suddenly go from 00000001 to 00000011 ).
Code ASM - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 .nolist .include "M2560DEF.INC" .list .def temp = R17 .def leds = R18 .def RS = R22 .cseg .org 0 ;Time Delay 2s ;Time Delay 2s tick_MAX: .dw $127A ; int(0.5 + (Base_Clock/Prescaler) * Delay) --> int(0.5 * (1.000.000/64 * 2) == 31.250 ($7A12) Prescaler Used: 64 ;Loading data from Program Memory (Flash - .cseg) ldi ZH, high(tick_MAX*2) ldi ZL, low(tick_MAX*2) lpm R19, Z+ lpm R20, Z ;Defining 16-bits TOP value to compare STS OCR1AH, R19 STS OCR1AL, R20 /* Setting WGM Mode (CTC) & Prescaler (1024) ================================================================================================================== TCCR1A – Timer/Counter 1 Control Register A Bit 7 6 5 4 3 2 1 0 (0x80) COM1A1 COM1A0 COM1B1 COM1B0 COM1C1 COM1C0 WGM11 WGM10 --> (TCCR1A) ================================================================================================================== TCCR1B – Timer/Counter 1 Control Register B Bit 7 6 5 4 3 2 1 0 (0x81) ICNC1 ICES1 – WGM13 WGM12 CS12 CS11 CS10 --> (TCCR1B) ================================================================================================================== CTC Mode (0100): WGMn3 WGMn2 WGMn1 WGMn0 (WGMn3 & WGMn2 -> TCCR1B) (WGMn1 & WGMn0 -> TCCR1A) Prescaler (011) : CS12 CS11 CS10 (CS12 CS11 CS10 -> TCCR1B) */ ldi temp, 0b00000000 STS TCCR1A, temp ldi temp, 0b00001011 STS TCCR1B, temp ;Data Direction OUTPUT (DDRB - Output DDRC - Input) LDI temp, 0b00000011 OUT DDRB, temp LDI temp, 0b00000000 OUT DDRC, temp ;Setting Initial Condition S --> HIGH // R --> LOW ldi RS, 0b00000010 OUT PORTB,RS CALL delay_loop ;+++++++++++++++++++++++++++ Wait Pess a Button +++++++++++++++++++ waitpress: in temp, PINC cpi temp, 0b00000000 ;0x00 means none pressed breq waitpress ;++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ ldi RS, 0b00000001 OUT PORTB,RS ;+++++++++++++++++++++++++++ Wait Release +++++++++++++++++++++++++ waitrelease: in temp, PINC cpi temp, 0b00000001 ;0xFF means none pressed breq waitrelease CALL delay_loop rjmp PC ;++++++++++++++++++++++++ Delay Loop ++++++++++++++++++++++ delay_loop: in temp, TIFR1 cpi temp, 0b00000000 breq delay_loop ldi temp, 1<<OCF1A out TIFR1, temp ;After Loop S --> HIGH // R --> HIGH ldi RS, 0b00000011 OUT PORTB,RS ret ;++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
