+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Newbie level 2
    Points: 22, Level: 1
    Join Date
    Apr 2018
    Posts
    Points
    22
    Level
    if statement within a generate for loop
    The algorithm:
    Z=0;
    for (i=0;i<n;i++){
    {Z=Z+j[i]k;}
    if (Z%2=1)
    { Z=Z+M;
       Z=Z/2;
    else
    {Z=Z/2;}}
    if (Z>M) {Z=Z-M;}
    The code i have written is as:
    module monto_arithmetic(j,k,n,y);
          input [7:0] j,k,n;
          output reg [7:0] y ;
          wire [7:0] p [0:7];
          wire [7:0] r [0:8];
          wire [7:0] l [0:8];
          wire o [0:7];
          wire g [0:7];
          wire [7:0] f;
          assign r[0]=8'b0;
          genvar i;
          generate for (i=0;i<8;i=i+1) begin:block1
              conditional_bit c0 (j[i],k,p[i]);
    	  adder_8bit_reversible t0 (p[i],r[i],1'b0,r[i+1],o[i]);
    	  assign f=r[i+1];
    	   if (f%2==1'b1) begin:block2
    	   adder_8bit_reversible t1 (r[i+1],n,1'b0,l[i],g[i]);
    	   assign l[i]=l[i]>>1;
    	   assign r[i]=l[i];
    	   end
               else begin
    	   assign r[i]=l[i];
               end
         end
         endgenerate
         assign y[7:0]=r[8];
         always @*
         begin
         if (y>n)
         assign y=y-n;
         end
         endmodule
    ERROR:HDLCompilers:277 - "monto_arithmetic.v" line 36 Illegal condition expression in generate
    if statement
    Can somebody point the mistake?
    •   Alt12th April 2018, 07:47
      advertising
  2. #2
    Advanced Member level 3
    Points: 5,094, Level: 16
    Join Date
    Feb 2015
    Posts
    849
    Points
    5,094
    Level
    16
    Re: if statement within a generate for loop
    f isn't a genvar. I think you want to instantiate the modules and then conditionally use the results.
  3. #3
    Newbie level 2
    Join Date
    Apr 2018
    Posts
    Points
    22
    Level
    The result of t0 which is r[i+1], I need to check if it is even or odd and the do the respective computations. Since f is 8bit, I cannot declare it as genvar . It again causes error.
    •   Alt12th April 2018, 10:03
      advertising
  4. #4
    Full Member level 1
    Points: 1,305, Level: 8
    Join Date
    Nov 2013
    Posts
    99
    Points
    1,305
    Level
    8
    I do not think you can use a "conditional generate" as you want (not completely sure however).
    The easier way I think is rethink the concept: make the generate to count to half (4 instead 8 in your example) and then generate two blocks: one for odd and other for even.
    1 members found this post helpful.
  5. #5
    Super Moderator
    Points: 28,564, Level: 41
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,540
    Points
    28,564
    Level
    41
    The f%2 is a problem in the if. If you want to check for even/odd values f[0] is what you perform the compare with, and then I wouldn't even use a compare...
    if (f[0]) begin : block1 // if f odd
    Haven't looked carefully at the rest of your code, but one observation is that you look like you don't care if the circuit is fast as you've got multiple passes through a bunch of combinational blocks instantiated multiple times. Direct translation of software loops usually end up this way. As the previous poster stated you should "rethink the concept".
    FYI HDL stands for Hardware Description Language. If you want to write C code and turn it into a circuit you should invest in Catapult C or one of the other HLS tools, instead of directly translating C code (or pseudo code) into Verilog)
  6. #6
    Join Date
    Feb 2015
    Posts
    849
    Points
    5,094
    Level
    16
    Looking at this again, I think the entire thing has flaws.
    The syntax error is because f[0] is a wire, but is used to generate an instance of the adder. f[0] isn't constant at compile time so the tools don't know what you want.
    But the rest of the code has multiple assignments to the same nets (within the same cycle) as well. These aren't syntax errors, but the design won't simulate correctly or synthesize.
    •   Alt12th April 2018, 17:05
      advertising
  7. #7
    Super Moderator
    Points: 241,298, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,879
    Points
    241,298
    Level
    100
    Do you understand that any condition evaluated in the generate construct must only depend on genvars and constants known at compile time? It doesn't look like array r complies to this prerequisite. If it's constant though, you may need to change the evaluation method.
  8. #8
    Full Member level 4
    Points: 1,498, Level: 8
    Join Date
    Oct 2015
    Posts
    237
    Points
    1,498
    Level
    8
    Look at this example and I am thinking about software trap to hardware designer.
    Still, it happends.
    If you break down the C code and take note on where intermediate variables have been used,
    it can be considered as FlipFlops on hardware code.
    A C for loop can be turned into a FIFO on hardware code.
    The rest of things are wires and functions.
    To improve one's brain, the doors are needed over the keys.
