Kintex Transceiver bank configuration
beginner_EDA
Full Member level 4
PCIE and 10 Gig need to be implemented in same kintex 7 series xc7k325t Transceiver bank 116. See attachment.
I am struggling to manage common block of transceiver bank. For 10 Gig I used QPLL and common block(using pcs/pma core) and intending to take only CPLL for PCIE(no common block) so that all in one transceiver bank fit. I generated PCIE in advanced mode by taking clock and common out of core (see attachment). but due to the need of several internal signals generation I am not directly instantiating the generated PCIE core in my design rather adding open IP example design. but still all the configuration in open example design is for QPLL.
Is it feasible??
Furthermore here is just part of open example design where generated core(pcie_7x_0) is instantiated and itself contain 2 common block which is not understandable:
Code Verilog - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
450
451
452
453
454
455
456
457
458
459
460
461
462
463
464
465
466
467
468
469
470
471
472
473
474
475
476
477
478
479
480
481
482
483
484
485
486
487
488
489
490
491
492
493
494
495
496
497
498
499
500
501
502
503
504
505
506
507
508
509
510
511
512
513
514
515
516
517
518
519
520
521
522
523
524
525
526
527
528
529
530
531
532
533
534
535
536
537
538
539
540
541
542
543
544
545
546
547
548
549
550
551
552
553
554
555
556
557
558
559
560
561
562
563
564
565
566
567
568
569
570
571
572
573
574
575
576
577
578
579
580
581
582
583
584
585
586
587
588
589
590
591
592
593
594
595
596
597
598
599
600
601
602
603
604
605
606
607
608
609
610
611
612
613
614
615
// Project    : Series-7 Integrated Block for PCI Express
// File       : pcie_7x_0_support.v
// Version    : 3.3
//-- Description:  PCI Express Endpoint Shared Logic Wrapper
`timescale 1ns / 1ps
(* DowngradeIPIdentifiedWarnings = "yes" *)
module pcie_7x_0_support # (
  parameter LINK_CAP_MAX_LINK_WIDTH = 8,                       // PCIe Lane Width
  parameter CLK_SHARING_EN          = "FALSE",                 // Enable Clock Sharing
  parameter C_DATA_WIDTH            = 256,                     // AXI interface data width
  parameter KEEP_WIDTH              = C_DATA_WIDTH / 8,        // TSTRB width
  parameter PCIE_REFCLK_FREQ        = 0,                       // PCIe reference clock frequency
  parameter PCIE_USERCLK1_FREQ      = 2,                       // PCIe user clock 1 frequency
  parameter PCIE_USERCLK2_FREQ      = 2,                       // PCIe user clock 2 frequency
  parameter PCIE_GT_DEVICE          = "GTX",                   // PCIe GT device
  parameter PCIE_USE_MODE           = "2.1"                    // PCIe use mode
  // PCI Express (pci_exp) Interface        //
  // Tx
  output  [(LINK_CAP_MAX_LINK_WIDTH - 1) : 0] pci_exp_txn,
  output  [(LINK_CAP_MAX_LINK_WIDTH - 1) : 0] pci_exp_txp,
  // Rx
  input   [(LINK_CAP_MAX_LINK_WIDTH - 1) : 0] pci_exp_rxn,
  input   [(LINK_CAP_MAX_LINK_WIDTH - 1) : 0] pci_exp_rxp,
  // Clocking Sharing Interface        //
  output                                     pipe_pclk_out_slave,
  output                                     pipe_rxusrclk_out,
  output [(LINK_CAP_MAX_LINK_WIDTH - 1) : 0] pipe_rxoutclk_out,
  output                                     pipe_dclk_out,
  output                                     pipe_userclk1_out,
  output                                     pipe_userclk2_out,
  output                                     pipe_oobclk_out,
  output                                     pipe_mmcm_lock_out,
  input  [(LINK_CAP_MAX_LINK_WIDTH - 1) : 0] pipe_pclk_sel_slave,
  input                                      pipe_mmcm_rst_n,
  // GT COMMON Sharing Interface        //
  output  [1:0]                              qpll_qplllock,
  output  [1:0]                              qpll_qplloutclk,
  output  [1:0]                              qpll_qplloutrefclk,
  // AXI-S Interface        //
  // Common
  output                                     user_clk_out,
  output                                     user_reset_out,
  output                                     user_lnk_up,
  output                                     user_app_rdy,
  input                                      tx_cfg_gnt,
  input                                      rx_np_ok,
  input                                      rx_np_req,
  input                                      cfg_turnoff_ok,
  input                                      cfg_trn_pending,
  input                                      cfg_pm_halt_aspm_l0s,
  input                                      cfg_pm_halt_aspm_l1,
  input                                      cfg_pm_force_state_en,
  input    [1:0]                             cfg_pm_force_state,
  input    [63:0]                            cfg_dsn,
  input                                      cfg_pm_send_pme_to,
  input    [7:0]                             cfg_ds_bus_number,
  input    [4:0]                             cfg_ds_device_number,
  input    [2:0]                             cfg_ds_function_number,
  input                                      cfg_pm_wake,
  // AXI TX
  input   [C_DATA_WIDTH-1:0]                 s_axis_tx_tdata,
  input                                      s_axis_tx_tvalid,
  output                                     s_axis_tx_tready,
  input   [KEEP_WIDTH-1:0]                   s_axis_tx_tkeep,
  input                                      s_axis_tx_tlast,
  input   [3:0]                              s_axis_tx_tuser,
  // AXI RX
  output  [C_DATA_WIDTH-1:0]                 m_axis_rx_tdata,
  output                                     m_axis_rx_tvalid,
  input                                      m_axis_rx_tready,
  output  [KEEP_WIDTH-1:0]                   m_axis_rx_tkeep,
  output                                     m_axis_rx_tlast,
  output  [21:0]                             m_axis_rx_tuser,
  // Flow Control
  output  [11:0]                             fc_cpld,
  output  [7:0]                              fc_cplh,
  output  [11:0]                             fc_npd,
  output  [7:0]                              fc_nph,
  output  [11:0]                             fc_pd,
  output  [7:0]                              fc_ph,
  input   [2:0]                              fc_sel,
  // Configuration (CFG) Interface        //
  // EP and RP                                      //
  output                                     tx_err_drop,
  output                                     tx_cfg_req,
  output  [5:0]                              tx_buf_av,
  output   [15:0]                            cfg_status,
  output   [15:0]                            cfg_command,
  output   [15:0]                            cfg_dstatus,
  output   [15:0]                            cfg_dcommand,
  output   [15:0]                            cfg_lstatus,
  output   [15:0]                            cfg_lcommand,
  output   [15:0]                            cfg_dcommand2,
  output   [2:0]                             cfg_pcie_link_state,
  output                                     cfg_to_turnoff,
  output   [7:0]                             cfg_bus_number,
  output   [4:0]                             cfg_device_number,
  output   [2:0]                             cfg_function_number,
  output                                     cfg_pmcsr_pme_en,
  output   [1:0]                             cfg_pmcsr_powerstate,
  output                                     cfg_pmcsr_pme_status,
  output                                     cfg_received_func_lvl_rst,
  // RP Only                                        //
  output                                     cfg_bridge_serr_en,
  output                                     cfg_slot_control_electromech_il_ctl_pulse,
  output                                     cfg_root_control_syserr_corr_err_en,
  output                                     cfg_root_control_syserr_non_fatal_err_en,
  output                                     cfg_root_control_syserr_fatal_err_en,
  output                                     cfg_root_control_pme_int_en,
  output                                     cfg_aer_rooterr_corr_err_reporting_en,
  output                                     cfg_aer_rooterr_non_fatal_err_reporting_en,
  output                                     cfg_aer_rooterr_fatal_err_reporting_en,
  output                                     cfg_aer_rooterr_corr_err_received,
  output                                     cfg_aer_rooterr_non_fatal_err_received,
  output                                     cfg_aer_rooterr_fatal_err_received,
  // VC interface        //
  output   [6:0]                              cfg_vc_tcvc_map,
  // Management Interface
  output   [31:0]                             cfg_mgmt_do,
  output                                      cfg_mgmt_rd_wr_done,
  input    [31:0]                             cfg_mgmt_di,
  input    [3:0]                              cfg_mgmt_byte_en,
  input    [9:0]                              cfg_mgmt_dwaddr,
  input                                       cfg_mgmt_wr_en,
  input                                       cfg_mgmt_rd_en,
  input                                       cfg_mgmt_wr_readonly,
  input                                       cfg_mgmt_wr_rw1c_as_rw,
  // Error Reporting Interface
  input                                       cfg_err_ecrc,
  input                                       cfg_err_ur,
  input                                       cfg_err_cpl_timeout,
  input                                       cfg_err_cpl_unexpect,
  input                                       cfg_err_cpl_abort,
  input                                       cfg_err_posted,
  input                                       cfg_err_cor,
  input                                       cfg_err_atomic_egress_blocked,
  input                                       cfg_err_internal_cor,
  input                                       cfg_err_malformed,
  input                                       cfg_err_mc_blocked,
  input                                       cfg_err_poisoned,
  input                                       cfg_err_norecovery,
  input   [47:0]                              cfg_err_tlp_cpl_header,
  output                                      cfg_err_cpl_rdy,
  input                                       cfg_err_locked,
  input                                       cfg_err_acs,
  input                                       cfg_err_internal_uncor,
  // AER interface        //
  input   [127:0]                             cfg_err_aer_headerlog,
  input   [4:0]                               cfg_aer_interrupt_msgnum,
  output                                      cfg_err_aer_headerlog_set,
  output                                      cfg_aer_ecrc_check_en,
  output                                      cfg_aer_ecrc_gen_en,
  output                                      cfg_msg_received,
  output   [15:0]                             cfg_msg_data,
  output                                      cfg_msg_received_pm_as_nak,
  output                                      cfg_msg_received_setslotpowerlimit,
  output                                      cfg_msg_received_err_cor,
  output                                      cfg_msg_received_err_non_fatal,
  output                                      cfg_msg_received_err_fatal,
  output                                      cfg_msg_received_pm_pme,
  output                                      cfg_msg_received_pme_to_ack,
  output                                      cfg_msg_received_assert_int_a,
  output                                      cfg_msg_received_assert_int_b,
  output                                      cfg_msg_received_assert_int_c,
  output                                      cfg_msg_received_assert_int_d,
  output                                      cfg_msg_received_deassert_int_a,
  output                                      cfg_msg_received_deassert_int_b,
  output                                      cfg_msg_received_deassert_int_c,
  output                                      cfg_msg_received_deassert_int_d,
  // EP Only                                        //
  // Interrupt Interface Signals
  input                                       cfg_interrupt,
  output                                      cfg_interrupt_rdy,
  input                                       cfg_interrupt_assert,
  input    [7:0]                              cfg_interrupt_di,
  output   [7:0]                              cfg_interrupt_do,
  output   [2:0]                              cfg_interrupt_mmenable,
  output                                      cfg_interrupt_msienable,
  output                                      cfg_interrupt_msixenable,
  output                                      cfg_interrupt_msixfm,
  input                                       cfg_interrupt_stat,
  input    [4:0]                              cfg_pciecap_interrupt_msgnum,
  // Physical Layer Control and Status (PL) Interface                                                               //
  // EP and RP                                      //
  input    [1:0]                              pl_directed_link_change,
  input    [1:0]                              pl_directed_link_width,
  input                                       pl_directed_link_speed,
  input                                       pl_directed_link_auton,
  input                                       pl_upstream_prefer_deemph,
  output                                      pl_sel_lnk_rate,
  output   [1:0]                              pl_sel_lnk_width,
  output   [5:0]                              pl_ltssm_state,
  output   [1:0]                              pl_lane_reversal_mode,
  output                                      pl_phy_lnk_up,
  output   [2:0]                              pl_tx_pm_state,
  output   [1:0]                              pl_rx_pm_state,
  output                                      pl_link_upcfg_cap,
  output                                      pl_link_gen2_cap,
  output                                      pl_link_partner_gen2_supported,
  output   [2:0]                              pl_initial_link_width,
  output                                      pl_directed_change_done,
  // EP Only                                        //
  output                                      pl_received_hot_rst,
  // RP Only                                        //
  input                                       pl_transmit_hot_rst,
  input                                       pl_downstream_deemph_source,
  // PCIe DRP (PCIe DRP) Interface        //
  input                                       pcie_drp_clk,
  input                                       pcie_drp_en,
  input                                       pcie_drp_we,
  input    [8:0]                              pcie_drp_addr,
  input    [15:0]                             pcie_drp_di,
  output                                      pcie_drp_rdy,
  output   [15:0]                             pcie_drp_do,
  input                                       sys_clk,
  input                                       sys_rst_n
  // Wires used for external clocking connectivity
  wire                                        pipe_pclk_out;
  wire                                        pipe_txoutclk_in;
  wire [(LINK_CAP_MAX_LINK_WIDTH - 1) : 0]    pipe_rxoutclk_in;
  wire [(LINK_CAP_MAX_LINK_WIDTH - 1) : 0]    pipe_pclk_sel_in;
  wire                                        pipe_gen3_in;
  // Wires used for external GT COMMON connectivity
  wire [11:0]                                 qpll_drp_crscode;
  wire [17:0]                                 qpll_drp_fsm;
  wire [1:0]                                  qpll_drp_done;
  wire [1:0]                                  qpll_drp_reset;
  wire                                        qpll_qplld;
  wire [1:0]                                  qpll_qpllreset;
  wire                                        qpll_drp_clk;
  wire                                        qpll_drp_rst_n;
  wire                                        qpll_drp_ovrd;
  wire                                        qpll_drp_gen3;
  wire                                        qpll_drp_start;
      //---------- PIPE Clock Shared Mode ------------------------------//
pcie_7x_0_pipe_clock #
          .PCIE_ASYNC_EN                  ( "FALSE" ),                 // PCIe async enable
          .PCIE_TXBUF_EN                  ( "FALSE" ),                 // PCIe TX buffer enable for Gen1/Gen2 only
          .PCIE_LANE                      ( LINK_CAP_MAX_LINK_WIDTH ), // PCIe number of lanes
          // synthesis translate_off
          .PCIE_LINK_SPEED                ( 2 ),
          // synthesis translate_on
          .PCIE_REFCLK_FREQ               ( PCIE_REFCLK_FREQ ),        // PCIe reference clock frequency
          .PCIE_USERCLK1_FREQ             ( PCIE_USERCLK1_FREQ ),      // PCIe user clock 1 frequency
          .PCIE_USERCLK2_FREQ             ( PCIE_USERCLK2_FREQ ),      // PCIe user clock 2 frequency
          .PCIE_DEBUG_MODE                ( 0 )
      pipe_clock_i
          //---------- Input -------------------------------------
          .CLK_CLK                        ( sys_clk ),
          .CLK_TXOUTCLK                   ( pipe_txoutclk_in ),     // Reference clock from lane 0
          .CLK_RXOUTCLK_IN                ( pipe_rxoutclk_in ),
          .CLK_RST_N                      ( pipe_mmcm_rst_n ),      // Allow system reset for error_recovery
          .CLK_PCLK_SEL                   ( pipe_pclk_sel_in ),
          .CLK_PCLK_SEL_SLAVE             ( pipe_pclk_sel_slave),
          .CLK_GEN3                       ( pipe_gen3_in ),
          //---------- Output ------------------------------------
          .CLK_PCLK                       ( pipe_pclk_out),
          .CLK_PCLK_SLAVE                 ( pipe_pclk_out_slave),
          .CLK_RXUSRCLK                   ( pipe_rxusrclk_out),
          .CLK_RXOUTCLK_OUT               ( pipe_rxoutclk_out),
          .CLK_DCLK                       ( pipe_dclk_out),
          .CLK_OOBCLK                     ( pipe_oobclk_out),
          .CLK_USERCLK1                   ( pipe_userclk1_out),
          .CLK_USERCLK2                   ( pipe_userclk2_out),
          .CLK_MMCM_LOCK                  ( pipe_mmcm_lock_out)
//Reference Clock for CPLLPD Fix
  wire gt_cpllpdrefclk;
  BUFG cpllpd_refclk_inst (.I (sys_clk), .O (gt_cpllpdrefclk));
    //---------- GT COMMON Shared Mode ------------------------------//
pcie_7x_0_gt_common #
            .PCIE_USE_MODE                  (PCIE_USE_MODE),          // PCIe use mode
            .PCIE_GT_DEVICE                 (PCIE_GT_DEVICE),         // GT in use
                .PCIE_SIM_MODE                  ("TRUE"),                 // PCIe sim mode
                .PCIE_REFCLK_FREQ               (PCIE_REFCLK_FREQ)            // PCIe reference clock frequency
            gt_common_i_0
                .PIPE_CLK                       (sys_clk),
                .CPLLPDREFCLK                   (gt_cpllpdrefclk),
                .QPLL_QPLLPD                    (qpll_qplld),
                .QPLL_QPLLRESET                 (qpll_qpllreset[0]),
                .QPLL_DRP_CLK                   (qpll_drp_clk ),
                .QPLL_DRP_RST_N                 (qpll_drp_rst_n),
                .QPLL_DRP_OVRD                  (qpll_drp_ovrd ),
                .QPLL_DRP_GEN3                  (qpll_drp_gen3),
                .QPLL_DRP_START                 (qpll_drp_start),
                .QPLL_DRP_CRSCODE               (qpll_drp_crscode[5:0]),
                .QPLL_DRP_FSM                   (qpll_drp_fsm [8:0]),
                .QPLL_DRP_DONE                  (qpll_drp_done[0]),
                .QPLL_DRP_RESET                 (qpll_drp_reset[0]),
                .QPLL_QPLLOUTCLK                (qpll_qplloutclk[0]),
                .QPLL_QPLLOUTREFCLK             (qpll_qplloutrefclk[0]),
                .QPLL_QPLLLOCK                  (qpll_qplllock [0])
                gt_common_i_1
                .QPLL_QPLLRESET                 (qpll_qpllreset[1]),
                .QPLL_DRP_CRSCODE               (qpll_drp_crscode[11:6]),
                .QPLL_DRP_FSM                   (qpll_drp_fsm [17:9]),
                .QPLL_DRP_DONE                  (qpll_drp_done[1]),
                .QPLL_DRP_RESET                 (qpll_drp_reset[1]),
                .QPLL_QPLLOUTCLK                (qpll_qplloutclk[1]),
                .QPLL_QPLLOUTREFCLK             (qpll_qplloutrefclk[1]),
                .QPLL_QPLLLOCK                  (qpll_qplllock [1])
pcie_7x_0 pcie_7x_0_i
    .pci_exp_txn(pci_exp_txn),
    .pci_exp_txp(pci_exp_txp),
    .pci_exp_rxn(pci_exp_rxn),
    .pci_exp_rxp(pci_exp_rxp),
    .pipe_pclk_in(pipe_pclk_out),
    .pipe_rxusrclk_in(pipe_rxusrclk_out),
    .pipe_rxoutclk_in(pipe_rxoutclk_out),
    .pipe_mmcm_rst_n(pipe_mmcm_rst_n),
    .pipe_dclk_in(pipe_dclk_out),
    .pipe_userclk1_in(pipe_userclk1_out),
    .pipe_userclk2_in(pipe_userclk2_out),
  .pipe_oobclk_in( pipe_oobclk_out ),
    .pipe_mmcm_lock_in(pipe_mmcm_lock_out),
    .pipe_txoutclk_out(pipe_txoutclk_in),
    .pipe_rxoutclk_out(pipe_rxoutclk_in),
    .pipe_pclk_sel_out(pipe_pclk_sel_in),
    .pipe_gen3_out(pipe_gen3_in),
    .user_clk_out(user_clk_out),
    .user_reset_out(user_reset_out),
    .user_lnk_up(user_lnk_up),
    .user_app_rdy(user_app_rdy),
    .s_axis_tx_tdata(s_axis_tx_tdata),
    .s_axis_tx_tvalid(s_axis_tx_tvalid),
    .s_axis_tx_tready(s_axis_tx_tready),
    .s_axis_tx_tkeep(s_axis_tx_tkeep),
    .s_axis_tx_tlast(s_axis_tx_tlast),
    .s_axis_tx_tuser(s_axis_tx_tuser),
    .m_axis_rx_tdata(m_axis_rx_tdata),
    .m_axis_rx_tvalid(m_axis_rx_tvalid),
    .m_axis_rx_tready(m_axis_rx_tready),
    .m_axis_rx_tkeep(m_axis_rx_tkeep),
    .m_axis_rx_tlast(m_axis_rx_tlast),
    .m_axis_rx_tuser(m_axis_rx_tuser),
    .tx_cfg_gnt(tx_cfg_gnt),
    .rx_np_ok(rx_np_ok),
    .rx_np_req(rx_np_req),
    .cfg_trn_pending(cfg_trn_pending),
    .cfg_pm_halt_aspm_l0s(cfg_pm_halt_aspm_l0s),
    .cfg_pm_halt_aspm_l1(cfg_pm_halt_aspm_l1),
    .cfg_pm_force_state_en(cfg_pm_force_state_en),
    .cfg_pm_force_state(cfg_pm_force_state),
    .cfg_dsn(cfg_dsn),
    .cfg_turnoff_ok(cfg_turnoff_ok),
    .cfg_pm_wake(cfg_pm_wake),
    .cfg_pm_send_pme_to(cfg_pm_send_pme_to),
    .cfg_ds_bus_number(cfg_ds_bus_number),
    .cfg_ds_device_number(cfg_ds_device_number),
    .cfg_ds_function_number(cfg_ds_function_number),
    .fc_cpld(fc_cpld),
    .fc_cplh(fc_cplh),
    .fc_npd(fc_npd),
    .fc_nph(fc_nph),
    .fc_pd(fc_pd),
    .fc_ph(fc_ph),
    .fc_sel(fc_sel),
    .cfg_mgmt_do(cfg_mgmt_do),
    .cfg_mgmt_rd_wr_done(cfg_mgmt_rd_wr_done),
    .cfg_mgmt_di(cfg_mgmt_di),
    .cfg_mgmt_byte_en(cfg_mgmt_byte_en),
    .cfg_mgmt_dwaddr(cfg_mgmt_dwaddr),
    .cfg_mgmt_wr_en(cfg_mgmt_wr_en),
    .cfg_mgmt_rd_en(cfg_mgmt_rd_en),
    .cfg_mgmt_wr_readonly(cfg_mgmt_wr_readonly),
    .cfg_mgmt_wr_rw1c_as_rw(cfg_mgmt_wr_rw1c_as_rw),
    .tx_buf_av(tx_buf_av),
    .tx_err_drop(tx_err_drop),
    .tx_cfg_req(tx_cfg_req),
    .cfg_status(cfg_status),
    .cfg_command(cfg_command),
    .cfg_dstatus(cfg_dstatus),
    .cfg_dcommand(cfg_dcommand),
    .cfg_lstatus(cfg_lstatus),
    .cfg_lcommand(cfg_lcommand),
    .cfg_dcommand2(cfg_dcommand2),
    .cfg_pcie_link_state(cfg_pcie_link_state),
    .cfg_pmcsr_pme_en(cfg_pmcsr_pme_en),
    .cfg_pmcsr_powerstate(cfg_pmcsr_powerstate),
    .cfg_pmcsr_pme_status(cfg_pmcsr_pme_status),
    .cfg_vc_tcvc_map(cfg_vc_tcvc_map),
    .cfg_to_turnoff(cfg_to_turnoff),
    .cfg_bus_number(cfg_bus_number),
    .cfg_device_number(cfg_device_number),
    .cfg_function_number(cfg_function_number),
    .cfg_bridge_serr_en(cfg_bridge_serr_en),
    .cfg_slot_control_electromech_il_ctl_pulse(cfg_slot_control_electromech_il_ctl_pulse),
    .cfg_root_control_syserr_corr_err_en(cfg_root_control_syserr_corr_err_en),
    .cfg_root_control_syserr_non_fatal_err_en(cfg_root_control_syserr_non_fatal_err_en),
    .cfg_root_control_syserr_fatal_err_en(cfg_root_control_syserr_fatal_err_en),
    .cfg_root_control_pme_int_en(cfg_root_control_pme_int_en),
    .cfg_aer_rooterr_corr_err_reporting_en(cfg_aer_rooterr_corr_err_reporting_en),
    .cfg_aer_rooterr_non_fatal_err_reporting_en(cfg_aer_rooterr_non_fatal_err_reporting_en),
    .cfg_aer_rooterr_fatal_err_reporting_en(cfg_aer_rooterr_fatal_err_reporting_en),
    .cfg_aer_rooterr_corr_err_received(cfg_aer_rooterr_corr_err_received),
    .cfg_aer_rooterr_non_fatal_err_received(cfg_aer_rooterr_non_fatal_err_received),
    .cfg_aer_rooterr_fatal_err_received(cfg_aer_rooterr_fatal_err_received),
    .cfg_received_func_lvl_rst(cfg_received_func_lvl_rst),
    .cfg_err_ecrc(cfg_err_ecrc),
    .cfg_err_ur(cfg_err_ur),
    .cfg_err_cpl_timeout(cfg_err_cpl_timeout),
    .cfg_err_cpl_unexpect(cfg_err_cpl_unexpect),
    .cfg_err_cpl_abort(cfg_err_cpl_abort),
    .cfg_err_posted(cfg_err_posted),
    .cfg_err_cor(cfg_err_cor),
    .cfg_err_atomic_egress_blocked(cfg_err_atomic_egress_blocked),
    .cfg_err_internal_cor(cfg_err_internal_cor),
    .cfg_err_malformed(cfg_err_malformed),
    .cfg_err_mc_blocked(cfg_err_mc_blocked),
    .cfg_err_poisoned(cfg_err_poisoned),
    .cfg_err_norecovery(cfg_err_norecovery),
    .cfg_err_tlp_cpl_header(cfg_err_tlp_cpl_header),
    .cfg_err_cpl_rdy(cfg_err_cpl_rdy),
    .cfg_err_locked(cfg_err_locked),
    .cfg_err_acs(cfg_err_acs),
    .cfg_err_internal_uncor(cfg_err_internal_uncor),
    .cfg_aer_ecrc_check_en(cfg_aer_ecrc_check_en),
    .cfg_aer_ecrc_gen_en(cfg_aer_ecrc_gen_en),
    .cfg_err_aer_headerlog(cfg_err_aer_headerlog),
    .cfg_err_aer_headerlog_set(cfg_err_aer_headerlog_set),
    .cfg_aer_interrupt_msgnum(cfg_aer_interrupt_msgnum),
    .cfg_interrupt(cfg_interrupt),
    .cfg_interrupt_rdy(cfg_interrupt_rdy),
    .cfg_interrupt_assert(cfg_interrupt_assert),
    .cfg_interrupt_di(cfg_interrupt_di),
    .cfg_interrupt_do(cfg_interrupt_do),
    .cfg_interrupt_mmenable(cfg_interrupt_mmenable),
    .cfg_interrupt_msienable(cfg_interrupt_msienable),
    .cfg_interrupt_msixenable(cfg_interrupt_msixenable),
    .cfg_interrupt_msixfm(cfg_interrupt_msixfm),
    .cfg_interrupt_stat(cfg_interrupt_stat),
    .cfg_pciecap_interrupt_msgnum(cfg_pciecap_interrupt_msgnum),
    .cfg_msg_received(cfg_msg_received),
    .cfg_msg_data(cfg_msg_data),
    .cfg_msg_received_pm_as_nak(cfg_msg_received_pm_as_nak),
    .cfg_msg_received_setslotpowerlimit(cfg_msg_received_setslotpowerlimit),
    .cfg_msg_received_err_cor(cfg_msg_received_err_cor),
    .cfg_msg_received_err_non_fatal(cfg_msg_received_err_non_fatal),
    .cfg_msg_received_err_fatal(cfg_msg_received_err_fatal),
    .cfg_msg_received_pm_pme(cfg_msg_received_pm_pme),
    .cfg_msg_received_pme_to_ack(cfg_msg_received_pme_to_ack),
    .cfg_msg_received_assert_int_a(cfg_msg_received_assert_int_a),
    .cfg_msg_received_assert_int_b(cfg_msg_received_assert_int_b),
    .cfg_msg_received_assert_int_c(cfg_msg_received_assert_int_c),
    .cfg_msg_received_assert_int_d(cfg_msg_received_assert_int_d),
    .cfg_msg_received_deassert_int_a(cfg_msg_received_deassert_int_a),
    .cfg_msg_received_deassert_int_b(cfg_msg_received_deassert_int_b),
    .cfg_msg_received_deassert_int_c(cfg_msg_received_deassert_int_c),
    .cfg_msg_received_deassert_int_d(cfg_msg_received_deassert_int_d),
    .pl_directed_link_change(pl_directed_link_change),
    .pl_directed_link_width(pl_directed_link_width),
    .pl_directed_link_speed(pl_directed_link_speed),
    .pl_directed_link_auton(pl_directed_link_auton),
    .pl_upstream_prefer_deemph(pl_upstream_prefer_deemph),
    .pl_sel_lnk_rate(pl_sel_lnk_rate),
    .pl_sel_lnk_width(pl_sel_lnk_width),
    .pl_ltssm_state(pl_ltssm_state),
    .pl_lane_reversal_mode(pl_lane_reversal_mode),
    .pl_phy_lnk_up(pl_phy_lnk_up),
    .pl_tx_pm_state(pl_tx_pm_state),
    .pl_rx_pm_state(pl_rx_pm_state),
    .pl_link_upcfg_cap(pl_link_upcfg_cap),
    .pl_link_gen2_cap(pl_link_gen2_cap),
    .pl_link_partner_gen2_supported(pl_link_partner_gen2_supported),
    .pl_initial_link_width(pl_initial_link_width),
    .pl_directed_change_done(pl_directed_change_done),
    .pl_received_hot_rst(pl_received_hot_rst),
    .pl_transmit_hot_rst(pl_transmit_hot_rst),
    .pl_downstream_deemph_source(pl_downstream_deemph_source),
    .pcie_drp_clk(pcie_drp_clk),
    .pcie_drp_en(pcie_drp_en),
    .pcie_drp_we(pcie_drp_we),
    .pcie_drp_addr(pcie_drp_addr),
    .pcie_drp_di(pcie_drp_di),
    .pcie_drp_rdy(pcie_drp_rdy),
    .pcie_drp_do(pcie_drp_do),
    .qpll_drp_crscode(qpll_drp_crscode),
    .qpll_drp_fsm(qpll_drp_fsm),
    .qpll_drp_done(qpll_drp_done),
    .qpll_drp_reset(qpll_drp_reset),
    .qpll_qplllock(qpll_qplllock),
    .qpll_qplloutclk(qpll_qplloutclk),
    .qpll_qplloutrefclk(qpll_qplloutrefclk),
    .qpll_qplld(qpll_qplld),
    .qpll_qpllreset(qpll_qpllreset),
    .qpll_drp_clk(qpll_drp_clk),
    .qpll_drp_rst_n(qpll_drp_rst_n),
    .qpll_drp_ovrd(qpll_drp_ovrd),
    .qpll_drp_gen3(qpll_drp_gen3),
    .qpll_drp_start(qpll_drp_start),
    .sys_clk(sys_clk),
    .sys_rst_n(sys_rst_n)
endmodule
Any suggestion how to edit this for my case?
Another thing in page 11 of this link
https://www.xilinx.com/support/documentation/ip_documentation/pcie_7x/v3_0/pg054-7series-pcie.pdf
For xc7k325t: location of PCIE is only X0Y0 for Integrated Block for PCIe Location which is location of common block in another Transceiver bank 115 and not 116 which I am using. Does it also make any trouble?
