CataM
- Joined
- Dec 23, 2015
- Messages
- 1,275
- Helped
- 314
- Reputation
- 628
- Reaction score
- 312
- Trophy points
- 83
- Location
- Madrid, Spain
- Activity points
- 8,409
Hello everyone,
I am unable to achieve the steady-state of the converter attached in PLECS. A bit of explanation about the converter is here.
Running a transient simulation, I see that steady-state is achieved starting at about 1.45*10^(-2) seconds (Cout initial voltage set to 12 V).
I set the parameters for the steady state as follows:
Since Vout freq is 200kHz => system period: 5e-6
Number of init cycles: 1.45*10^(-2)*200kHz=2900
Are these settings reasonable ?
Should I run the simulation with only one scope (the scope from the output) so that the simulation focuses on the output ?
P.D.: Notice that I am running the converter without the voltage regulation around CMC.
Any hint or comment is appreciated.
