RF Absorber Sticking
TXRX
Full Member level 2
I want to stick the attached absorber ECCOSORB MCS from Laird company to aluminium sheet, i did not receive a recommendation from Laird, Which Glue can do the job ?
Thanks,
any semiflexible glue that does not dissolve the foam. RTV should work.
be advised that a lot of glues do not actually "stick" to aluminum, and you actually have to prime the aluminum surface with paint first....
The ECCOSORB MCS is type of silicon, the aluminium has chemical coating will it improve the "stick" ?
