Hello,
I asked this question already on alteraforum.com but got no answer...
My design - targeted for an Arria V GX FPGA requires an 8b/10b encoded single lane transceiver operating at 1.868 GHz.
I decided to use the Native Tranciever Phy IP core for this purpose:
https://www.altera.com/content/dam/a...user_guide.pdf
On the Tx side I'd like to send 2 bytes per a 93.44 MHz clock.
The document in the above link mentions that tx_parallel_data is 44 bits wide.
At page #272 table 10-13 describes a possible double byte configuration that would allow me to achieve the desired configuration.
It's called: "Double word data bus, byte serializer disabled".
Unfortunately, I can't find a way to configure the core to use this configuration...
