Results 1 to 6 of 6
    Member level 4
    Points: 657, Level: 5
    Sep 2016
    75
    657
    Assignment of DSP Slices in FPGA
    Hello, there are DSP slices in Modren FPGAs. Do they work on single clock cycle ? for example if an FPGA has 220 DSP slices and each can support and can handle the multiplication of 18 x 25, does this means that this operation will be done in single clock cycle by each DSP slice ?
    Second question how to assign intentionally a DSP slice in VHDL code. Is it possible to assign intentionally ? Following is an example.
    architecture behav of multiply_unsigned is
    begin
    Res <= A * B;
    end behav;
    Is this (assignment of DSP slices) done automatically during synthesis and tool optimization or can be done manually in VHDL code ?
    •   Alt6th April 2018, 10:07
      advertising
    Points: 35,892, Level: 46
    Jun 2010
    6,567
    35,892
    46
    Re: Assignment of DSP Slices in FPGA
    This is referred to as inferring hardware from behavioural VHDL code. If your code matches a template that the synth tool matches, then it will recognise your behavioural code as a candidate for specific hardware.
    But you need to understand the DSP slices - both altera and Xilinx have documentation for their devices and their synth tool that tell you how to code for them.
    So to answer your questions
    1. The actual multiplier itself is not clocked, but is it surrounded by registers that are. So yes, the result will always be computed in a single clock cycle, and you can add extra pipe stages in the slice depending on how you configure it (or infer it). Synth tool also offer register retiming, where pipe stages after a multiply can be moved around by the synth tool to use the internal registers more efficiently than you coded. But yes, an 18x25 can be done in a single cycle. You could even do a 72x72 in a single cycle, as the architecture allows chaining of DSPs (but dont forget about designing your timing).
    2. Your code should infer an un-clocked DSP.
    Some features of the DSP may not be available from inference, and you may need to generate a core and instantiate it in your VHDL. But in most cases, inference is fine.
    •   Alt6th April 2018, 10:34
      advertising
    Points: 12,344, Level: 26
    Aug 2011
    2,501
    12,344
    26
    As it's not under a clocked process - the above code will infer a multiplier whose result will be available in "ZERO" clocks (not one clock).
    As with any combinatoric logic they'll be an output delay, it's somewhat incorrect to analyze this delay in term of "number of clocks it will take"...
    With that said, embedded FPGA multipliers are highly optimized areas of silicon that have a very low time to output - and therefore are capable of being integrated in designs that are run at high speeds (even without pipe-lining the multiplication ITSELF).
    Even though, if the design allows - it's a good idea to register the output of the multiplier to ease the tools timing efforts when connecting it to the upstream logic (this register is free as it's part of the DSP block).
    process ( clock )
    begin
    if rising_edge ( clock ) then
    result <= a*b ;
    end if ;
    end process ;
    •   Alt6th April 2018, 12:35
      advertising
    Member level 4
    Sep 2016
    75
    657
    Is there any example to add a DSP slice as component in VHDL module and then instantiate the slice by using Port Map ?
    Aug 2011
    2,501
    12,344
    26
    Not sure what you'd get of it but here's an example of instantiating Xilinx's DSP48 block:
    --   DSP48E1   : In order to incorporate this function into the design,
    --    VHDL     : the following instance declaration needs to be placed
    --  instance   : in the body of the design code.  The instance name
    -- declaration : (DSP48E1_inst) and/or the port declarations after the
    --    code     : "=>" declaration maybe changed to properly reference and
    --             : connect this function to the design.  All inputs and outputs
    --             : must be connected.
    --   Library   : In addition to adding the instance declaration, a use
    -- declaration : statement for the UNISIM.vcomponents library needs to be
    --     for     : added before the entity declaration.  This library
    --   Xilinx    : contains the component declarations for all Xilinx
    -- primitives  : primitives and points to the models that will be used
    --             : for simulation.
    --  Copy the following two statements and paste them before the
    --  Entity declaration, unless they already exist.
    Library UNISIM;
    use UNISIM.vcomponents.all;
    -- <-----Cut code below this line and paste into the architecture body---->
       -- DSP48E1: 48-bit Multi-Functional Arithmetic Block
       --          Artix-7
       -- Xilinx HDL Language Template, version 2017.4
       DSP48E1_inst : DSP48E1
       generic map (
          -- Feature Control Attributes: Data Path Selection
          A_INPUT => "DIRECT",               -- Selects A input source, "DIRECT" (A port) or "CASCADE" (ACIN port)
          B_INPUT => "DIRECT",               -- Selects B input source, "DIRECT" (B port) or "CASCADE" (BCIN port)
          USE_DPORT => FALSE,                -- Select D port usage (TRUE or FALSE)
          USE_MULT => "MULTIPLY",            -- Select multiplier usage ("MULTIPLY", "DYNAMIC", or "NONE")
          USE_SIMD => "ONE48",               -- SIMD selection ("ONE48", "TWO24", "FOUR12")
          -- Pattern Detector Attributes: Pattern Detection Configuration
          AUTORESET_PATDET => "NO_RESET",    -- "NO_RESET", "RESET_MATCH", "RESET_NOT_MATCH"
          MASK => X"3fffffffffff",           -- 48-bit mask value for pattern detect (1=ignore)
          PATTERN => X"000000000000",        -- 48-bit pattern match for pattern detect
          SEL_MASK => "MASK",                -- "C", "MASK", "ROUNDING_MODE1", "ROUNDING_MODE2"
          SEL_PATTERN => "PATTERN",          -- Select pattern value ("PATTERN" or "C")
          USE_PATTERN_DETECT => "NO_PATDET", -- Enable pattern detect ("PATDET" or "NO_PATDET")
          -- Register Control Attributes: Pipeline Register Configuration
          ACASCREG => 1,                     -- Number of pipeline stages between A/ACIN and ACOUT (0, 1 or 2)
          ADREG => 1,                        -- Number of pipeline stages for pre-adder (0 or 1)
          ALUMODEREG => 1,                   -- Number of pipeline stages for ALUMODE (0 or 1)
          AREG => 1,                         -- Number of pipeline stages for A (0, 1 or 2)
          BCASCREG => 1,                     -- Number of pipeline stages between B/BCIN and BCOUT (0, 1 or 2)
          BREG => 1,                         -- Number of pipeline stages for B (0, 1 or 2)
          CARRYINREG => 1,                   -- Number of pipeline stages for CARRYIN (0 or 1)
          CARRYINSELREG => 1,                -- Number of pipeline stages for CARRYINSEL (0 or 1)
          CREG => 1,                         -- Number of pipeline stages for C (0 or 1)
          DREG => 1,                         -- Number of pipeline stages for D (0 or 1)
          INMODEREG => 1,                    -- Number of pipeline stages for INMODE (0 or 1)
          MREG => 1,                         -- Number of multiplier pipeline stages (0 or 1)
          OPMODEREG => 1,                    -- Number of pipeline stages for OPMODE (0 or 1)
          PREG => 1                          -- Number of pipeline stages for P (0 or 1)
       port map (
          -- Cascade: 30-bit (each) output: Cascade Ports
          ACOUT => ACOUT,                   -- 30-bit output: A port cascade output
          BCOUT => BCOUT,                   -- 18-bit output: B port cascade output
          CARRYCASCOUT => CARRYCASCOUT,     -- 1-bit output: Cascade carry output
          MULTSIGNOUT => MULTSIGNOUT,       -- 1-bit output: Multiplier sign cascade output
          PCOUT => PCOUT,                   -- 48-bit output: Cascade output
          -- Control: 1-bit (each) output: Control Inputs/Status Bits
          OVERFLOW => OVERFLOW,             -- 1-bit output: Overflow in add/acc output
          PATTERNBDETECT => PATTERNBDETECT, -- 1-bit output: Pattern bar detect output
          PATTERNDETECT => PATTERNDETECT,   -- 1-bit output: Pattern detect output
          UNDERFLOW => UNDERFLOW,           -- 1-bit output: Underflow in add/acc output
          -- Data: 4-bit (each) output: Data Ports
          CARRYOUT => CARRYOUT,             -- 4-bit output: Carry output
          P => P,                           -- 48-bit output: Primary data output
          -- Cascade: 30-bit (each) input: Cascade Ports
          ACIN => ACIN,                     -- 30-bit input: A cascade data input
          BCIN => BCIN,                     -- 18-bit input: B cascade input
          CARRYCASCIN => CARRYCASCIN,       -- 1-bit input: Cascade carry input
          MULTSIGNIN => MULTSIGNIN,         -- 1-bit input: Multiplier sign input
          PCIN => PCIN,                     -- 48-bit input: P cascade input
          -- Control: 4-bit (each) input: Control Inputs/Status Bits
          ALUMODE => ALUMODE,               -- 4-bit input: ALU control input
          CARRYINSEL => CARRYINSEL,         -- 3-bit input: Carry select input
          CLK => CLK,                       -- 1-bit input: Clock input
          INMODE => INMODE,                 -- 5-bit input: INMODE control input
          OPMODE => OPMODE,                 -- 7-bit input: Operation mode input
          -- Data: 30-bit (each) input: Data Ports
          A => A,                           -- 30-bit input: A data input
          B => B,                           -- 18-bit input: B data input
          C => C,                           -- 48-bit input: C data input
          CARRYIN => CARRYIN,               -- 1-bit input: Carry input signal
          D => D,                           -- 25-bit input: D data input
          -- Reset/Clock Enable: 1-bit (each) input: Reset/Clock Enable Inputs
          CEA1 => CEA1,                     -- 1-bit input: Clock enable input for 1st stage AREG
          CEA2 => CEA2,                     -- 1-bit input: Clock enable input for 2nd stage AREG
          CEAD => CEAD,                     -- 1-bit input: Clock enable input for ADREG
          CEALUMODE => CEALUMODE,           -- 1-bit input: Clock enable input for ALUMODE
          CEB1 => CEB1,                     -- 1-bit input: Clock enable input for 1st stage BREG
          CEB2 => CEB2,                     -- 1-bit input: Clock enable input for 2nd stage BREG
          CEC => CEC,                       -- 1-bit input: Clock enable input for CREG
          CECARRYIN => CECARRYIN,           -- 1-bit input: Clock enable input for CARRYINREG
          CECTRL => CECTRL,                 -- 1-bit input: Clock enable input for OPMODEREG and CARRYINSELREG
          CED => CED,                       -- 1-bit input: Clock enable input for DREG
          CEINMODE => CEINMODE,             -- 1-bit input: Clock enable input for INMODEREG
          CEM => CEM,                       -- 1-bit input: Clock enable input for MREG
          CEP => CEP,                       -- 1-bit input: Clock enable input for PREG
          RSTA => RSTA,                     -- 1-bit input: Reset input for AREG
          RSTALLCARRYIN => RSTALLCARRYIN,   -- 1-bit input: Reset input for CARRYINREG
          RSTALUMODE => RSTALUMODE,         -- 1-bit input: Reset input for ALUMODEREG
          RSTB => RSTB,                     -- 1-bit input: Reset input for BREG
          RSTC => RSTC,                     -- 1-bit input: Reset input for CREG
          RSTCTRL => RSTCTRL,               -- 1-bit input: Reset input for OPMODEREG and CARRYINSELREG
          RSTD => RSTD,                     -- 1-bit input: Reset input for DREG and ADREG
          RSTINMODE => RSTINMODE,           -- 1-bit input: Reset input for INMODEREG
          RSTM => RSTM,                     -- 1-bit input: Reset input for MREG
          RSTP => RSTP                      -- 1-bit input: Reset input for PREG
       -- End of DSP48E1_inst instantiation
    •   Alt6th April 2018, 19:45
      advertising
    Full Member level 1
    Points: 1,305, Level: 8
    Nov 2013
    99
    1,305
    8
    Name the FPGA you intend to use, or at least the FPGA family, it will help us to help you.
    For example, for Xilinx Spartan-6: see https://www.xilinx.com/support/docum...ides/ug389.pdf
    For Family 7 (Spartan, Artix, Kintex): https://www.xilinx.com/support/docum...es_DSP48E1.pdf
