+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Member level 4
    Points: 657, Level: 5
    Join Date
    Sep 2016
    Posts
    75
    Points
    657
    Level
    Behavioral, RTL, Structural and Gate Level - how to differentiate them in VHDL
    Hello,
    RTL is synthesizeable while Behavioral is not synthesizeable because it contain loops, wait statements. Is this statement true ? What about if Behavioral does not contain loops and wait statements ? The following example is synthesizeable and represents Behavioral modeling.
    entity half_adder is
      port (a, b: in std_logic;
        sum, carry_out: out std_logic);
      end half_adder;
    architecture behavior of half_adder is
      begin
        ha: process (a, b)
        begin
          if a = ‘1’ then
            sum <= not b;
            carry_out <= b;
          else
            sum <= b;
            carry_out <= ‘0’;
          end if;
        end process ha;
    end behavior;
    I am wondering what is the main difference between Behavioral, RTL, Structural and Gate Level in VHDL. Could anyone share example of each ? There are some posts regarding this issue but they are old and I don't know if is there any change in definition or concepts over the years ? because there are some tools which can synthesize loops. Where can I find VHDL - 2008 user guide ?
    •   Alt6th April 2018, 08:35
      advertising
  2. #2
    Advanced Member level 3
    Points: 5,102, Level: 16
    Join Date
    Feb 2015
    Posts
    849
    Points
    5,102
    Level
    16
    Re: Behavioral, RTL, Structural and Gate Level - how to differentiate them in VHDL
    These terms are not accurate. There is a synthesizable subset of VHDL (and Verilog).
    Your code seems to be a behavioral description within a module used for structural modeling.
    •   Alt6th April 2018, 08:42
      advertising
  3. #3
    Member level 4
    Join Date
    Sep 2016
    Posts
    75
    Points
    657
    Level
    Quote Originally Posted by vGoodtimes View Post
    Is there any reference document which describe these terms for VHDL 2008 ?
    •   Alt6th April 2018, 09:11
      advertising
  4. #4
    Advanced Member level 5
    Points: 35,892, Level: 46
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,567
    Points
    35,892
    Level
    46
    RTL, Behavioural and Structural terms are not connected directly to VHDL. RTL has generally become a term to mean synthesisable HDL. But RTL code can contain behavioural features (Inference of RAMs, DSP etc).
    Strutural generally means HDL full of entity instantiations. But usually it goes alongside some RTL in the same file too.
    RTL, Behavioural and Structoral are not mutually exclusive things. In the past, they may have been when synthesis tools were not so good at understanding HDL, and were less flexible in the code they allowed - And these idea remains. But now these terms are mostly redundant. Most people just refer to "synthesisable" and "non-synthesisable" code. The subset that is synthesisable continues to grow.
    Gate Level generally refers to simulation of a netlist (not written by a human - unless you're a masochist)
    I would describe the code you posted as RTL. If it contained loops and was still synthesisable I would still call it RTL.
    Decent guides on the changes for VHDL 2008 are here:
    https://www.doulos.com/knowhow/vhdl_...ide/vhdl_2008/
    and a webinar here:
    https://www.doulos.com/content/events/VHDL_2008.php
