Results 1 to 4 of 4
    Full Member level 4
    Points: 1,635, Level: 9
    Jul 2014
    203
    1,635
    9
    declaring a constant value for all modules in verilog
    hi,
    i had some 40 nos of 32 bit constant in a verilog module used for some calculations. i am replicating this module for some 10 times.
    so basically i am repeating the values in all the modules and wasting resources. so is it possible to declare it only once and use it in all the 10 modules.
    10 instantiations are from the same module.
    i declared it like this.
    reg [15:0] mem [0:40];
    so instead of repeating like this in all modules is it possible to declare only once and use it in all the 10 modules?
    how can i do it? if it do so will it reduce the logic utilization?
    any help is really appriciated
    thanks and regards
    •   Alt6th April 2018, 06:12
      advertising
    Points: 241,298, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,879
    241,298
    100
    Re: declaring a constant value for all modules in verilog
    Constants known at synthesis time are inserted in each expression separately. The definition method doesn't affect the logic or memory utilization. It's only a question of effective code writing.
    In the System Verilog world, packages are a suitable way to define global constants (as in VHDL since ever).
    In plain Verilog, including constant definitions is probably the best way.
    •   Alt6th April 2018, 06:30
      advertising
    Full Member level 4
    Jul 2014
    203
    1,635
    9
    hi,
    so if i use some compiler directive like `include (or some other way)and include all of my constants,
    it won't help me to reduce my logic utilization right?
    while elaborating, it will assigned in each module separately ... is it?
    thanks
    •   Alt6th April 2018, 07:26
      advertising
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,879
    241,298
    100
    Yes. There are however some cases where array constants can be more effectively implemented as initialized block ram, e.g. when multiple constants are muxed to a single target.
