neazoi
Advanced Member level 6
Hi, I am thinking of the filter method of SSB generation. In the simplest form, the 0.3-3khz audio is mixed with the bfo to produce both sidebands in the IF, then an IF filter (crystal or mechanical) is used to remove one of these sidebands. This requires difficult to build crystal filters.
I am thinking of a way to relax the need for so strict filters. If the 0.3-3khz audio was somehow "shifted" in the audio domain (say 17.3-20khz) and then using this shifted audio signal for the mixing to RF, then the two sidebands produced by the bfo (information passband signals within the sidebands) would be several khz apart. Two signals of about 35KHz may be easier to filter even with a good LC filter.
How does this idea sound to you? This isn't the way the weaver method works I think.
