[SOLVED] [ASK] jumps to a specific address in STM32 Cortex-M3
Ahmad Edi Saputra
Junior Member level 2
[ASK] jump to specific address in STM32 Cortex-M3
Hi
i am currently using stm32f103C8, i want to build a custom bootloader in address 0x8000000 and my application will placed in 0x8008000.
in cortex M4 (stm32f407vgtx) i manage to jump to address 0x8008000 with these code
if (((*(__IO uint32_t*)APPLICATION_ADDRESS) & 0x2FFE0000 ) == 0x20000000){
      JumpAddress = *(__IO uint32_t*) (APPLICATION_ADDRESS + 4);
      Jump_To_Application = (pFunction) JumpAddress;
      __set_MSP(*(__IO uint32_t*) APPLICATION_ADDRESS);
      Jump_To_Application();
but these code seem doesn't work in cortex M3, i tried a few modification. like bellow, it doesn't work either. i am sure my application already in place. i check address 0x8008000 during debug, my binary app was already there, and yes i compile it with address 0x8008000
//JumpAddress = *(__IO uint32_t*) (APPLICATION_ADDRESS + 4);
//Jump_To_Application = (pFunction) JumpAddress;
stackAddress = *(__IO uint32_t*) APPLICATION_ADDRESS;
SCB->VTOR = APPLICATION_ADDRESS;
__set_MSP(stackAddress);
//Jump_To_Application();
NVIC_SystemReset();
Best Regards
Edi
Re: [ASK] jump to specific address in STM32 Cortex-M3
typedef void (*pFunction)(void);
pFunction Jump_To_Application;
uint32_t JumpAddress;
..........YOUR CODE.............
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, MAIN_FLASH_OFFSET);
	__disable_irq();
  JumpAddress = *(__IO uint32_t*) (MAIN_FLASH_OFFSET + 4);
  __set_MSP(*(__IO uint32_t*) MAIN_FLASH_OFFSET);
Thanks for your answer
	__disable_irq();
i've tried, but it jump to the next instruction. here is what i meant
	NVIC_SetVectorTable(NVIC_VectTab_FLASH, APPLICATION_ADDRESS);
	__disable_irq();
//next instruction
and if i do without calling Jump_To_Application() my bootloader back to main again after all statement in if block is executed. i have no idea why. what do you think?
is a the value in pointer address, not value of pointer itself. Just your misunderstanding I suppose.
i tried to dig deeper, i break down the different hex from STM32f103 and STMF407, bellow is the hex i break down base on intel hex format. i found very interesting fact, that changes of ROM address in keil make no effect for stm32f103 (generated hex is exactly the same), but it has effect on stm32f407. i assume that start address in stm32f407's hex change (0000 and 8000) and i think jump command has also pointed to different location (9D01 and 9D81. i have not found a way to change ROM for stm32f1 yet, any idea?
stm32f103 address 0x8000000
:02 0000 04 0800 F2
:10 0000 00 C8060020 A901 0008 AD01 0008 AF01 0008 E2
:10 0010 00 B101 0008 B301 0008 B501 0008 0000 0000 AC
stm32f103 address 0x8008000
:02 0000 04 0800 F2
stm32f407 address 0x8000000
:02 0000 04 0800 F2
:10 0000 00 28990020 9D01 0008 5D09 0008 5909 0008 91
:10 0010 00 5B09 0008 9902 0008 C739 0008 0000 0000 C9
stm32f407 address 0x8008000
:02 0000 04 0800 F2
:10 8000 00 28990020 9D81 0008 5D89 0008 5989 0008 91
:10 8010 00 5B89 0008 9982 0008 C7B9 0008 0000 0000 C9
yah, it is the value from memory address (APPLICATION_ADDRESS or MAIN_FLASH_OFFSET). when i debug, it already has the correct value, if not, it would not be executed at the first time, i mean there is an if to make sure stack pointer has correct offset from 0x20000000
//something here
i think i just figured that out. its definitely linker problem, i change rom base address in the linker option. thanks, i'll mark as resolved
