+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Advanced Member level 5
    Points: 12,344, Level: 26
    Join Date
    Aug 2011
    Posts
    2,501
    Points
    12,344
    Level
    26
    Converting an array of std_logic to string
    Hello,
    My entity's "generic" section has a set of 5 enabling configurations (that are concatenated into a vector ) - as follows:
    entity some_entity is
    generic
       enable_0 : std_logic ;
       enable_1 : std_logic ;
       enable_2 : std_logic ;
       enable_3 : std_logic ;
       enable_4 : std_logic ;
    port
    end entity some_entity ;
    architecture rtl_some_entity is
    constant concatenated_enables : std_logic_vector ( 4 downto 0 ) := enable_4 & enable_3 & enable_2 & enable_1 & enable_0 ;
    constant configuration_sting : string := std_logic_vector_to_string (concatenated_enables ) ;
    begin
    end architecture rtl_some_entity ;
    The function marked in red shall return the Hex value of "concatenated_enables" in a string format.
    For example:
    if
    enable_4 = '1' ;
    enable_3 = '1' ;
    enable_2 = '1' ;
    enable_1 = '0' ;
    enable_0 = '0' ;
    so
    configuration_sting = "FC"
    if
    enable_4 = '0' ;
    enable_3 = '1' ;
    enable_2 = '1' ;
    enable_1 = '0' ;
    enable_0 = '0' ;
    configuration_sting = "0C"
  2. #2
    Super Moderator
    Points: 57,700, Level: 58
    Achievements:
    7 years registered
    Awards:
    Most Frequent Poster 3rd Helpful Member
    Join Date
    Apr 2014
    Posts
    11,765
    Points
    57,700
    Level
    58
    Re: Converting an array of std_logic to string
    Hj,
    if
    enable_4 = '1' ;
    enable_3 = '1' ;
    enable_2 = '1' ;
    enable_1 = '0' ;
    enable_0 = '0' ;
    so
    Why "FC"? I'd expect "1C"
    (Corrected: "8C" --> "1C")
    I'd divide it into 4 bit nibbles.
    The values are 0...15
    For values of 0...9 you could add 0x30 to get values 0x30 ... 0x39 which are the ASCII values if "0" ..."9".
    For the other values add (0x41 - 0x0A) = 0x37 to get values 0x41 .... 0x46 which are "A" ... "F"
    Klaus
    Please don´t contact me via PM, because there is no time to respond to them. Thank you.
    •   Alt30th March 2018, 12:06
      advertising
  3. #3
    Points: 35,892, Level: 46
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,567
    Points
    35,892
    Level
    46
    Cant even be bothered to try yourself now?
    vhdl 2008 has to_string and to_hstring functions for all types, including std_logic_vector.
      advertising
  4. #4
    Super Moderator
    Points: 241,686, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,971
    Points
    241,686
    Level
    100
    Do you have any specific question about writing the std_logic_vector_to_string() function?
    I presume you mean "1C" instead of "FC".
    TrickyDicky is right. to_hstring() does exactly what you want. You may want to copy the code if it isn't provided by your compiler/simulator.
    •   Alt30th March 2018, 12:19
      advertising
  5. #5
    Join Date
    Aug 2011
    Posts
    2,501
    Points
    12,344
    Level
    26
    I tried using the 2008 "to_string" function before posting...
    But as far as I understand (correct me if I'm wrong) - it wouldn't convert the "concatenated_enables" std_logic_vector to an ASCII hex string...it would leave it in a binary format.
    I guess this can be solved by writing a custom function that converts 4 binary nibbles into characters that represent the hex value - but I want to avoid this.
    My question is - how ?
  6. #6
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,567
    Points
    35,892
    Level
    46
    use to_hstring instead.
    1 members found this post helpful.
  7. #7
    Join Date
    Aug 2011
    Posts
    2,501
    Points
    12,344
    Level
    26
    You mean:
    hex_string := to_string ( enable_4 & enable_3 & enable_2 & enable_1 & enable_0) ;
  8. #8
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,567
    Points
    35,892
    Level
    46
    constant configuration_sting : string := to_hstring(concatenated_enables );
    •   Alt30th March 2018, 20:04
      advertising
  9. #9
    Join Date
    Aug 2011
    Posts
    2,501
    Points
    12,344
    Level
    26
    Sorry, that's what I meant..
    Thanks.
    How well is this function supported with Vivado and Quartus?
  10. #10
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,567
    Points
    35,892
    Level
    46
    No idea. Why dont you tell us?
