sakibnaz
Full Member level 3
Hi all.
I am doing a project where I have Stepper Motor. Most of the case I am driving the Motor using Stepper Driver which works via SPI. And I can track the Motor position when I made Move.
But in some case I need to Move the Motor Manually by hand. And need to track the position as well. So when the Driver starts operating then I can compensate the Manual hand move position.
Any idea if its possible?
Also I am using high torque Stepper NEMA 17 14:1 Gear. And its difficult to move by hand as the shaft is tight. Any other type Stepper Motor type I can consider in my choice? If its possible to control the shaft tightness via electronics will be great. Any idea?
Thanks in advance.
Regards.
Thanks in advance.
Regards.
