tejakrishna
Newbie level 1
hello everyone,
I interfaced sim 300 with raspberry pi 2. when I run the code for
AT+ --response was OK.
for remaining there is no response
help me
this is the code
help me
this is the code
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 import serial import RPi.GPIO as GPIO import os, time GPIO.setmode(GPIO.BOARD) port = serial.Serial("/dev/ttyAMA0", baudrate=9600, timeout=1) # Enable Serial comm.. # Transmitting AT Commands to the Modem port.write('AT'.encode()+'\r\n'.encode()) # '\r\n' indicates the Enter key rcv = port.read(10) print (rcv) time.sleep(1) port.write('ATE0'.encode()+'\r\n'.encode()) # Disable the Echo rcv = port.read(10) print (rcv) time.sleep(1) port.write('AT+CMGF=1'.encode()+'\r\n'.encode()) #Select Message format as Txt mode rcv = port.read(10) print (rcv) time.sleep(1) port.write('AT+CNMI=2,1,0,0,0'.encode()+'\r\n'.encode()) #New SMS Message Indications rcv = port.read(10) print (rcv) time.sleep(1) port.write('AT+CMGS="9652157636"'.encode()+'\r\n'.encode()) # Sending a message rcv = port.read(10) print (rcv) time.sleep(1) port.write('temperature is 27 C'.encode()+'\r\n'.encode()) # Message rcv = port.read(10) print (rcv) port.write('message from sim 300'.encode()+'\r\n'.encode()) # Message rcv = port.read(10) print (rcv) port.write("\x1A".encode()) # Enable to send SMS for i in range(10): rcv = port.read(10) print (rcv)
